honda crv 2003 central locking
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=119714
Printed Date: April 10, 2026 at 2:10 AM
Topic: honda crv 2003 central locking
Posted By: ashwin
Subject: honda crv 2003 central locking
Date Posted: January 28, 2010 at 3:51 PM
Dear people, i hope someone could help me, i have an european model crv from 2003, i build a clifford matrix alarm in it with the wiring diagram from this site, only i cant get the central locking to work, i have an original honda transmitter to open and close the doors, according to several wiring diagrams there should be a WHITE/ blue and a WHITE/ green cabel in the drivers kick panel in a gray plug, i simply don't have these wires in this plug, when i open the doors with the transmitter or with the drivers doorlock i hear a relay klicking under the dash so there should be some wires somewhere where i can connect my open and close wires from my alarm system,can someone tell me where i can find these wires for an european model, thanks in advance, ashwin Honda CRV 2.0 build 2003
Posted By: kreg357
Date Posted: January 28, 2010 at 4:02 PM
Not sure if there is a difference on the European models. But here is a link to a web site : https://www.bulldogsecurity.com/ They have some pictures of the lock/unlock wires you are looking for. Perhaps the difference is your drivers kick panel is on the right and ours is on the left. Did you try looking in the other kick panel? ------------- Soldering is fun!
Posted By: ashwin
Date Posted: January 28, 2010 at 4:28 PM
Hi kreg357, i live in the netherlands, we also have the steering wheel to the left, just like you, i looked on the website, can't find the pictures you're telling about just the same wiring diagram of the CR-V , can you send me those pics thanks in advance Ashwin
Posted By: x1le
Date Posted: January 28, 2010 at 4:34 PM
thanks in advance
Ashwin
look up your car and then scroll all the way down.
Posted By: kreg357
Date Posted: January 28, 2010 at 4:48 PM
The pictures are at the bottom of the wire listing. Quite a few actually. Here is a direct link to the lock/unlock wire picture. https://64.85.6.121/diagrams/Images.asp?ImageID=672&link=BULLDOG Looks like it is high up in the kick panel. ------------- Soldering is fun!
Posted By: ashwin
Date Posted: January 28, 2010 at 5:31 PM
Dear Kreg, i have a gray plug indeed but not the 2 wires,i do have the wire for the back glass to pop open, but not the two wires for central locking, i will t ake some pictures of my grayplug so you can see the difference, thanks in advance, ashwin
Posted By: t&t tech
Date Posted: January 28, 2010 at 6:56 PM
Doesn't that vehicle have a rocker switch to control the locks?
Posted By: ashwin
Date Posted: January 29, 2010 at 1:45 AM
No indeed, i can't lock the car from inside, i don't have a switch for it, i only got two original transmitters to open and close the doors and i can open and close all doors through the drivers cilinder doorlock., i really think the european crv's are different then the ones which are made for Us market. Infact i also don't have the green factory alarmplug next to the steering colum so thats why perhaps i don't have the 2 open/close wires in the grayplug. Still, when i open and close the doors with the transmitter i hear a relay clicking somewhere underneath the dash so there must be something to connect my alarm wires. Ashwin
Posted By: howie ll
Date Posted: January 29, 2010 at 2:01 AM
On earlier units the control relay unit was inside the driver's door, WHITE/ red lock motor wire and WHITE/ something unlock motor wire,TEST you need a 451m or two relays and 5 wire this setup.
