04 saturn ion passlock bypass
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=119901
Printed Date: April 02, 2026 at 1:42 PM
Topic: 04 saturn ion passlock bypass
Posted By: schroete
Subject: 04 saturn ion passlock bypass
Date Posted: February 04, 2010 at 1:19 PM
I have an 04 saturn ion that fails to start sometimes. I was wondering if I can read the resistance between the white and WHITE/ black wire while turning the key and then put a resistor from the bcm side of teh white to the ground (white with a blk stripe) and bypass the passlock and not have the passlock light on the dash. I am not putting a remote starter on the car.
Posted By: chev104275
Date Posted: February 04, 2010 at 1:41 PM
they have known problems with the ing switch i just did my sisters 03 ion   so far so good
Posted By: schroete
Date Posted: February 04, 2010 at 2:12 PM
chev104275,
did you take a ground to chasis ground as well or just use the WHITE/ blk wire?
Date Posted: February 04, 2010 at 2:27 PM
i replaced the ing switch with a new one   not bad took about 45 mins to remove and install and reset the passlock system   i think the switch was like 40 bucks
P.S you dont need a scan tool to reset the passlock
Posted By: ceasar326
Date Posted: February 06, 2010 at 12:43 AM
If your doing that then your better off getting a bypass module and bypassing it that way. Its easyer and safer. Just ground the statuse to ground
Posted By: monty_77
Date Posted: February 06, 2010 at 1:49 PM
the bypass would cost just as much as the ignition switch
