command start 310i
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=119927
Printed Date: April 02, 2026 at 7:59 PM
Topic: command start 310i
Posted By: nocrankcase777
Subject: command start 310i
Date Posted: February 05, 2010 at 11:17 PM
I recently bought a 1998 GMC Sierra that had at one point a remote starter in it, but the brain has been removed. I found the old manual under the seat and it says it was a Ungo by Clarion with a model number of CS200. I found this interesting, as all the Command Start remote starts start with CS. Even the antenna looks the same, just different symbol inthe middle. I checked and noticed the plugs would all fit in a Command Start 310i brain that I have. I don't have the wires from the brain I have to compare wire colors and positions, as I am not about to just plug it in and try it. What I need is the wire pattern for each plug color to prong. Using the diagram here https://www.the12volt.com/installbay/file.asp?ID=301 I need to know what color goes to each contact on the brain. If someone could match the color for each prong position of the plug, I could figure it out from there and make the plugs match, if they don't already. Go left to right on the 9-plug main harness reading down like you read and straight down on the Auxiliary plug. Can someone help make my brain work LOL.  Thanks James
Posted By: cwall
Date Posted: December 27, 2010 at 11:19 PM
I am in need of the programming for the command start cs310. The remote is a 4 button.
cwall
Date Posted: January 06, 2011 at 6:41 PM
After checking the wiring from another unit of the same model with wiring intact, I found the wiring harness in my truck went to the right places. I plugged the brain in and it works great!! Now I just need the program manual, so I can figure out how to program the second remote:o)
