remote start, 06 murano
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=120063
Printed Date: April 29, 2026 at 9:00 AM
Topic: remote start, 06 murano
Posted By: tahoehtp
Subject: remote start, 06 murano
Date Posted: February 11, 2010 at 1:51 PM
ok I bought fortin CAN SL2 and crimestopper SP-500 since they work with data-link
question is. all I need wire pretty much now is the remote start portion of alarm and power right? and just make sure to program the can-SL2 etc. is there anything I should watch for? I haven't done alarm install like in years... before remote start came out... things are different so I just wanted to check before I do it...
and this is going to 06 murano with no inteliigent key.
Posted By: tahoehtp
Date Posted: February 18, 2010 at 5:39 PM
Ok so for wiring, is this right? I'm double checking before I start get in to wiring them.
###SP-500 to car wiring:
starter wire socket:
red
red
pink
gray
brown
pink/white <- I'm not sure which wire to go
9wire harness:
blue/black <- (-)IGN or aux 2 what color or which wire?
Brown to siren
3wire harness
green to pin 13 on BCM
blue to pin 14 on BCM
###Fortin CAN-SL-PL
DATA LINK to SP-500
white to door pin <- which color?
4pin:
gray to pin 22 on BCM
gray/white to 21 on BCM
TruckinTube.com Owner.
Posted By: tahoehtp
Date Posted: February 18, 2010 at 7:21 PM
so form wiring info on here.
PART       COLOR      LOCATION      DIAGRAM
12 VOLT CONSTANT      BLUE/RED (+)       IGNITION SWITCH HARNESS
STARTER      BLUE (+)       IGNITION SWITCH HARNESS
STARTER 2      PINK (+)      IGNITION SWITCH HARNESS
IGNITION 1      BLACK (+)      IGNITION SWITCH HARNESS
IGNITION 2      N/A      N/A
IGNITION 3      N/A       N/A
ACCESSORY /HEATER BLOWER 1      WHITE (+)       IGNITION SWITCH HARNESS
ACCESSORY /HEATER BLOWER 2      N/A       N/A
and from SP-500
These to goes to 12V Battery
red
red
Brown goes to starter (which wire in above? Blue or Pink?)
Pink goes to IGN (which wire in aboce?)
Pink/White goes to Start/IGN/ACC
Gray ACC (ACCESSORY /HEATER BLOWER 1 aboce)
Posted By: tahoehtp
Date Posted: February 19, 2010 at 5:40 PM
OK wiring color was different... so I can use help where it goes...
12 VOLT CONSTANT GREEN (+) IGNITION SWITCH HARNESS
STARTER BLACK/ RED (+) IGNITION SWITCH HARNESS
STARTER 2 BLACK / YELLOW (+) IGNITION SWITCH HARNESS
IGNITION 1 BLACK/ RED (+) IGNITION SWITCH HARNESS
IGNITION 2 N/A N/A
IGNITION 3 N/A N/A
ACCESSORY /HEATER BLOWER 1 WHITE/ BLUE (+) IGNITION SWITCH HARNESS
ACCESSORY /HEATER BLOWER 2 RED (+) IGNITION SWITCH HARNESS
Brown(start) goes to BLACK/ RED or BLACK / YELLOW?
Pink(IGN) goes to RED?
Pink/White(START2/IGN2/ACC2) goes to ?
Gray(A/C) goes to WHITE/ blue
I can really use assistance... thank you..
