viper 5901 valet switch mounting
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=120094
Printed Date: April 28, 2026 at 7:55 AM
Topic: viper 5901 valet switch mounting
Posted By: ssbowtie1
Subject: viper 5901 valet switch mounting
Date Posted: February 13, 2010 at 9:33 AM
I'm installing a Viper 5901 in my 95 Pontiac Firebird and the valet switch isn't your conventional small switch you can mount anywhere. I was wondering where people were mounting their switches just to get some ideas.
Posted By: ceasar326
Date Posted: February 13, 2010 at 10:59 AM
valet switch? If i remember correctly its attach to the antenna so were ever you mounth the antenna the valet switch will be too. I guessing you mean the neutral safety switch, that i would mount by the fuses, kick panel center consol or somewere infront of the dash. Hope this helps.
Date Posted: February 13, 2010 at 11:09 AM
Thanks ceasar I'm referring to the control center that has the led and valet switch attached to it.
Date Posted: February 13, 2010 at 11:18 AM
I normally mount it in the mittle of the windshild by on top of the rearview mirror. Its better there since the blue LED is really bright lights up all the car. Its really visible, ive done a few.
