Viper 650 XV Installation Manual
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=12010
Printed Date: April 18, 2026 at 10:46 PM
Topic: Viper 650 XV Installation Manual
Posted By: JaysOnTheEdge
Subject: Viper 650 XV Installation Manual
Date Posted: April 09, 2003 at 5:05 PM
Does anyone know where i can find an Installation Manual for the Viper 650 XV alarm system i am going to hook up a central power locks aculators in a 2002 Ford Ranger myself to save money and i want to see what kind of power lock outputs the 650 VX has to make sure it will work right and if I should even bother doing the work or just have the viper dealer use thier actulators.
Posted By: x6369x
Date Posted: April 11, 2003 at 11:10 PM
Depends on how electronically/mechanically skilled you are. The only other parts you may need are relays.
The most difficult part, I think, would be removing the door panels and running the wire. Expect about an hour for each door. Most shops charge $50-75 per door for actuators.
------------- Friends Don't Let Friends Bump Stock.
