viper 791xv has shut down my durango
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=120147
Printed Date: April 28, 2026 at 12:35 AM
Topic: viper 791xv has shut down my durango
Posted By: kazeej
Subject: viper 791xv has shut down my durango
Date Posted: February 15, 2010 at 12:08 PM
2000 Dodge Durango Sport with a Viper 791XV w/remote start has been acting up for a while, and now my truck won't start at all.
A couple of months ago, the remote start would start the truck, but the brake would not cancel it. A few times it refused to start, but when it did start, it ran fine. A few weeks ago, I drove it about 10 miles, and parked it. Now it won't start. It cranks, but won't fire. If it does fire, it dies immediately. And the alarm had stopped arming.
I pulled the alarm out from under the dash and found 4 wires loose. One was the power - reconnected that, and the alarm started working again. I don't know where the other 3 go. They are orange, brown, and BLACK/ white.  Can someone tell me where these wires go? or point me in the right direction? It was installed by BestBuy. I would just take it back to them, but I'd have to tow the truck there.
Thanks in advance!
Jack
Posted By: t&t tech
Date Posted: February 15, 2010 at 3:50 PM
The immobiliser circuit of that alarm, only interrupts the starter, unless additional relays were used to interrupt other circuits, (hardly likely), as i know it's not practice in the states to interrupt fuel and ignition circuits! And also because you have the orange wire loose (GWA).
On this system there are two BLACK/ white and brown wires!
The black white on the H1 harness is the dome light trigger wire, the one on the smaller harness is the nss wire, this is supposed to be grounded, directly or through a switch
The brown on the H1 harness is the siren's positive feed, the brown on the harness with the nss wire is the brake shutdown wire (+).
Do you have a factory immobiliser?
Posted By: Chris Luongo
Date Posted: February 15, 2010 at 4:41 PM
Do the factory keys have a black plastic head or gray?
If it's gray, then you have Chrysler's Sentry Key anti theft system, and the problem could be there, or possibly with how the remote starter was interfaced to it.
Posted By: bambam3030
Date Posted: February 15, 2010 at 7:38 PM
It sounds like a car problem if you have the alarm unpluged but it might be a factory anti theft system if you have a gray key. If so you should be able to remove it from around your key cilinder its just a ruber ring and follow it down and unplug it from the bypass modual along with the other harness. then if that doesnt work it is yor car.
BAM
Posted By: kazeej
Date Posted: February 16, 2010 at 8:43 AM
The brown wire I found had pulled loose from the brake switch. It's connected now. The BLACK/ white was indeed grounded. It was jumpered to the main ground on another conntector.
I don't  think the orange was actually used. When I found it, it was taped to the red (12+) wire, but it did not appear to have been stripped. I think it was just taped out of the way.
I don't have any kind of factory immobilizer. In fact, the key I have been using was made an the local Home Depot.
I talked to my installer. He said putting it in valet mode would remove the alarm system from the equation, or I could try removing all the fuses. I tried both, and the truck didn't start. I think I have ruled out the alarm system. I pulled a spark plug to check for spark (which I should have done a long time ago) and it was wet with fuel - no spark. I think my problem lies elsewhere.
Thanks for the great advice. If / when I get this truck running again, I'll post what I found.
Jack
