valet 552t wont start.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=120167
Printed Date: May 04, 2026 at 7:13 AM
Topic: valet 552t wont start.
Posted By: lwilliams70
Subject: valet 552t wont start.
Date Posted: February 16, 2010 at 11:45 AM
Hey guys! I have a Valet 552t remote start on my 2000 Dodge Caravan that will not turn over the engine. I get no response from the Led. The remote has new batteries. Any Ideas? I checked all fuses. It was working fine up until last year and then didnt need it since it was getting warm.
------------- Lwilliams70
Posted By: t&t tech
Date Posted: February 16, 2010 at 11:52 AM
What happens when you try?
Date Posted: February 16, 2010 at 12:54 PM
Nothing. If I press the 1 button it will lock and unlock the doors. Nothing happens with the 2 or pressing both buttons.
Posted By: themobileguru
Date Posted: February 16, 2010 at 2:54 PM
Was a Hood Pin Switch installed?? If so, remove it...but also check to make sure your BLACK/ white wire coming off the starter is grounded properly, or that the Switch that the BLACK/ white wire is supposed to go to is turned on. Also, is your Brake Switch operating properly? Make sure the Brown wire is not getting a Positive reading. If the Brown wire is triggered by 12volt it will not allow the starter to activate.
Date Posted: February 16, 2010 at 3:04 PM
The Hood Pin Switch wire coming off the starter is Gray. Make sure that wire is not connected to anything, especially a ground. When that wire receives ground you cannot activate your starter. The lock/unlock will still work, but the starter won't. Hood pin switches are very unreliable because they corrode and THIS ISSUE happens.
