pilot doorlocks with hodl
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=120286
Printed Date: May 02, 2026 at 7:38 PM
Topic: pilot doorlocks with hodl
Posted By: settheray
Subject: pilot doorlocks with hodl
Date Posted: February 21, 2010 at 3:24 PM
I have an Autopage rs665 alarm/remote start installed in my 2005 Honda Pilot.
The remote start function works perfectly.
The unlock/disarm works perfectly.
Arm works, but it won't lock the doors.
Any ideas?
Thanks in advance.
If I knew everything about everything, I sure wouldn't be working here!
Posted By: i am an idiot
Date Posted: February 21, 2010 at 4:13 PM
Is the drivers door closed?
Is the key in the ignition?
Date Posted: February 21, 2010 at 10:02 PM
The door is closed.
The key is not in the ignition.
Date Posted: February 21, 2010 at 10:20 PM
Did you connect the keysense wire?  Is it possible that you connected the keysense wire to a wire that is always grounded?
