remote starter for 06 chevy enqinox
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=120463
Printed Date: May 03, 2026 at 10:38 PM
Topic: remote starter for 06 chevy enqinox
Posted By: mitsu79
Subject: remote starter for 06 chevy enqinox
Date Posted: March 02, 2010 at 6:07 PM
hi guys,
im installing a avital 4103 remote starter on 06 chevy equinox..the car doesn't have starter wire at the ignition harness..i'm using the xk06... the xk06 requires connect the orange wire to car starter wire.. i don't know where is the starter wire on this car.. is there any other way do by pass this car?
pp
Posted By: Mark Mizenko
Date Posted: March 02, 2010 at 9:27 PM
Connect that Orange wire to the Purple Starter Output Wire from the Avital unit.  The Purple wire only gets connected to the Orange wire, it is NOT connected to any starter wire in the car.
Posted By: kreg357
Date Posted: March 03, 2010 at 7:31 PM
An easy way to do this car is with the iDatalink bypass module.  The ADS DL unit flashed with the ADS DL(GM4) firmware will do the bypass and the cars Lock, UnLock, Arm, & DisArm.  I used the ADS DL module on a 05 Equinox LT and it worked like a champ.
The car actually starts when it sees the IGN & ACC signals go to +12v and then when the ACC signal drops, it starts (cranks) the engine.
