key pad issues
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=120522
Printed Date: May 03, 2026 at 1:34 PM
Topic: key pad issues
Posted By: menara024
Subject: key pad issues
Date Posted: March 05, 2010 at 11:38 AM
my keypad is not working on my 2000 mercury sable i know i have the right code and it doesnt light up to all the numbers like after the third digit it will light up?? i use it about once a year and now it dont work? any ideas or possible fixes??
Posted By: cpgoose
Date Posted: March 05, 2010 at 11:41 AM
Does it not light up at all, or do only certain numbers not light up? If it doesn't light up at all, then maybe it's a blown fuze?
Date Posted: March 05, 2010 at 11:53 AM
only to certain numbers and it dosnt lock when u push the 7/8 9/0 or whichever it is but they do light up and dome light come on
Posted By: chev104275
Date Posted: March 05, 2010 at 5:27 PM
if you remove the door panel then remove the key pad assy   you will most likely find corrision in the pad   very common in ford / mercury cars
you can replace the pad assy
Date Posted: March 13, 2010 at 4:16 PM
i did not find any corrison anything i can do besides replacing
Date Posted: March 13, 2010 at 8:28 PM
you may be able to take the pad apart and check the connections from the buttons to the board ive never done it   ive always replaced the pad assy
