Child Safety Door Lock Wire
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=12055
Printed Date: May 13, 2026 at 9:29 AM
Topic: Child Safety Door Lock Wire
Posted By: jinho27
Subject: Child Safety Door Lock Wire
Date Posted: April 10, 2003 at 8:34 PM
Hi, Where can I find the child safety door lock wire on 99 Camry? Thanks in advance.
Posted By: draasch
Date Posted: April 11, 2003 at 10:06 AM
* Child Safety Lock - BLUE/RED (-) In Same Connector As Door Lock Wires Above. ------------- Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Posted By: CCRoadshop
Date Posted: April 11, 2003 at 4:04 PM
make sure u Diode isolate it tho jinho
------------- Installer - Circuit City Roadshop(2 1/2 years n counting)
Alpine CDA7894(soon to be the cda9815)
Pioneer XM unit(soon to be direct link alpine)
Audiovox 995C alarm/remote start
Posted By: Chris Luongo
Date Posted: April 12, 2003 at 2:45 PM
Man, this website pisses me off sometimes! Half the stuff I post gets lost. Anyway, I'll try again.
It is not at all necessary to find or connecte the Unlock Detection wire, which is sometimes (mistakenly) called the child safety wire, on a '99 Camry.
Under certain conditions, the unlock function of the rocker switch on the door panel becomes disabled. This will happen if you do one of three things:
1. Lock the door using the key in the door.
2. Lock the door using the factory keyless.
3. Open a door, press the power lock button, and then close the door.
It's true that you can get around this feature the hard way-----if you pulse the rocker-switch unlock wire, and the unlock detection wire at the same time, the doors will unlock. But there is a far simpler way.
You'll notice that if you turn the key in the door, you can lock and unlock all the doors this way....the wires that come off the key cylinder are active at all times.
You should simply use the key-cylinder wires, and then diodes and multiple connections are unnecessary.
The necessary wires are at the large orange plug coming out the bottom of the fuse box.
The dark blue/white wire will test by turning the key in either door to the Lock position....pulsing this wire with your alarm will lock all doors.
The dark blue wire tests by turning the key in the passenger door to Unlock...pulsing this wire will unlock all doors at once.
There is another wire there, which tests by turning the key in the DRIVER'S door to the Unlock position.....I'm pretty sure it's GREEN/ red. If the car has factory Toyota keyless, one pulse to this wire will unlock the driver's door only; a second pulse will unlock all doors. If there is no factory keyless, a single pulse will do nothing, and a double pulse will unlock all doors.
Date Posted: April 13, 2003 at 8:09 AM
just hook it up....
