viper 5702 and ads al ca weirz problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=121001
Printed Date: April 04, 2026 at 4:07 AM
Topic: viper 5702 and ads al ca weirz problem
Posted By: mike08401
Subject: viper 5702 and ads al ca weirz problem
Date Posted: March 26, 2010 at 11:53 PM
I have the combo viper 5702(pink edition) and ADS AL CA installd in 2010 civic EX. all wires are connect as instructed. all function are working fine but door lock, unlock trunk release are working fine but remote start so wierz. when first start it will not work. it showed Immobile key problem but if I push unlock then push start it will start and then relock the door.but if it already start and then I stop and start in few minutes it will work fine but if I left it for a couple of hour problem start again. I'm not sure if any setting of viper need to be complete or if i miss something???
here the connection
Blue/white to GWR of viper
Red to 12volt
Back to Ground
GREEN/ Black to lock from viper
Blue/black to unlock from viper
RED / White to Trunk input frm Viper
Purple / YELLOW t ground
WHITE/ Black to Blue / YELLOW ADS
Blue/Red to Ground
Pink to pin2 Pink key immo
ORANGE / Black to Pin3 Key Immo
Orange to Pin4 Key Immo
Yellow/Black to green from viper
Yellow?red to Blue from Viper
Yellow to brown from viper
Posted By: tedmond
Date Posted: March 27, 2010 at 6:18 AM
huh?
do you wnat to reread what you wrote? its all over the map. so you cant start the car if its armed?
Ted
Compustar Expert
Date Posted: March 27, 2010 at 11:46 AM
Hahaha!
You were rite, I don't even understand myself I was half drunk when i posted(or may be too drunk)posted_image
Let make it simple
the combo was Viper 5702 pink edition and ADS-AL-CA and car is 2010 Honda EX
wires connect as follow
Red to 12volt
Back to Ground
Blue/Red to Ground
WHITE/ red to pin27, white(lock) to pin 28(unlock)of driver door harness connection back of fuse box
what's it does now if I press start button it will try to start but then failt and showed Immobil erro(key icon flashing on car dash panel) if i press unlock first the pressing start it will start and rearm itself as normal. all other function are working correct(Lock,Unlock,trunk release..)this just happen if i have car sit for couple of hour and it will remote start normal if i drive and stop for 10,15mins === So my question is:did i miss anything or some thing need to program onto viper brain to make it works??
   Thanksssssss
