single wire doorlock solution?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=121105
Printed Date: May 03, 2026 at 12:47 PM
Topic: single wire doorlock solution?
Posted By: spaceoff
Subject: single wire doorlock solution?
Date Posted: March 31, 2010 at 4:53 PM
hello all
i want to install a car alarm and became a little box with it called single wire doorlock solution, and i'm unsure for what it is. i have a mazda 6 2004 and figured out, that it has a single wire doorlock and a remote powerlock, but now i don't know for what this solution is for. is it ment for remote powerlock?
i would really appreciate an answer
thanks
Posted By: t&t tech
Date Posted: March 31, 2010 at 8:01 PM
What? posted_image Have you been drinking?
Do you have the alarm already? Your vehicle has a one wire system for lock and unlock!
Posted By: tedmond
Date Posted: March 31, 2010 at 8:06 PM
light green (-) @ bcm pin 7 of 24 pin plug.
Lock is negative trigger thru a 1000 ohm resistor. Unlock is a straight negative trigger. MUST use relays. The BCM (Body Control Module) is in the driver kick panel.
its called a multiplex system where resistance determines what it will do. so a 1000ohm resistor will lock. straigh ground will unlock, and as you know this is done through one wire.
Ted
Compustar Expert
Posted By: howie ll
Date Posted: April 01, 2010 at 12:34 AM
Hello All it's April 1st and I'm going to think OUT of my little box. Could that be a 2 into 1 resistive or relay plus lead. Oh why have I joined this post, it's going to run and run, oh yes I've got the flu and I stopped smoking 20 hours ago, everyone keep out of my way.
Posted By: spaceoff
Date Posted: April 01, 2010 at 2:20 AM
i guess i was drunk posted_image posted_image i was confused, because i told the dealer, that i already have remote powerlock, but probably he missunderestood and sent me the box with the car alarm just to be sure (i'm from switzerland, so i didn't quite understand the singel door stuff in the beginning). but when i read the diagramm it says output: door lock/unlock output        input: lock, unlock, +12V and ground
it also has a led and a little button, probably for programming the keys
Posted By: tedmond
Date Posted: April 01, 2010 at 5:40 AM
i hope youre not trying to fool us howie ahah.
happy april fools day folks.
Ted
Compustar Expert
Posted By: alarep5
Date Posted: April 01, 2010 at 9:00 AM
never seen an "adjustable" resistor door lock module
can you tell what the name, or model number is?
whatever it is, I'm sure it is more expensive than the 5 cent resistors that most of us usually use
OLDSCHOOL - If the wire is there,...use it.
Posted By: spaceoff
Date Posted: April 01, 2010 at 10:22 AM
it is called DLS single wire
here is what it looks like:
https://www.efunctional.com/scydlssw.html
and there is also a number, but i couldn't find anything related to this: FCC ID: OARRXAM2000
it is from scytek
Posted By: alarep5
Date Posted: April 01, 2010 at 1:22 PM
Can't tell from that view, does it have adjustement switches on the other end. Or how does it adjust for required resistor value?
Posted By: spaceoff
Date Posted: April 03, 2010 at 6:26 AM
no, it doesn't have an adjustment switch, only a button for probably programming the remote keys.
