unlock wire diode splitting mr2 92
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=121207
Printed Date: April 02, 2026 at 11:58 AM
Topic: unlock wire diode splitting mr2 92
Posted By: deusv
Subject: unlock wire diode splitting mr2 92
Date Posted: April 07, 2010 at 4:53 AM
Hi all,
I'm installing an alarm into a 1992 Toyota MR2 Turbo (Jap Import). The wiring colours are here:
https://www.the12volt.com/installbay/alarmdetail/2102.html
However, since this is a Jap import, the extra information below that I found somewhere else is required:
CDL Notes IMPORT MODELS - UNLOCK WIRE NEEDS DIVIDING BY 2 DIODES. 1 DIODE TO UNLOCK. 1 DIODE TO BLUE / YELLOW OR RED / YELLOW ON CDL RELAY.
My question is where and which orientation these diodes go?
Note: If I wire the alarm unlock directly to yellow/black and nowhere else, it will only work once before requiring a manual lock/unlock to work again - I think this is why the diodes are needed.
I have attached a crude diagram of how I think the system is supposed to be wired without the diodes.
Any help will be much appreciated!
Posted By: tedmond
Date Posted: April 07, 2010 at 5:51 AM
place diode silver band towards alarm. https://www.the12volt.com/diodes/diodes.asp
------------- Ted
Compustar Expert
Posted By: deusv
Date Posted: April 07, 2010 at 5:55 AM
Thank you for your quick reply. I'll try it out tonight!
Posted By: howie ll
Date Posted: April 07, 2010 at 8:48 AM
I find this very hard to understand, the only time you would need diodes would be if you were using a DEI product with just the flip flop (2 wire) rather than relay driven outputs. I did an alarm R/S in one recently, I've done about 25 of these over the years and NEVER needed diodes.
Posted By: deusv
Date Posted: April 07, 2010 at 9:16 AM
Believe me I wish I didn't have to use diodes - but if I only connect the (-) unlock output to yellow/black then it doesn't work properly. As mentioned, it will work the first time but after that you have to manually lock with the key and/or cycle the ignition before you can unlock with the fob. This is the 3rd time installing an alarm onto this car and the previous 2 had the same problem. This time I hope to get it right - I'll let you know how it goes.
If you're interested, I have the official circuit diagram of the vehicles door lock system which I would be happy to upload if you would like to have a look. The only thing is that it's for US spec cars, though most of it should be the same.
Posted By: howie ll
Date Posted: April 07, 2010 at 1:07 PM
This is starting to wiz me off, I even checked Directechs for confirmation. Just take a 12volt test light one side to ground then probe the plugs in the driver's kick panel. One wire will give you lock, the other unlock, NO DIODES that's it. Just one question, what brand and model of alarm?
All regional variations, Japanese, US and Europe used the same locking systems, Euro versions had a factory alarm module in the right side rear quarter, giving you back trunk, engine bay, front(?) and door triggers.
Posted By: deusv
Date Posted: April 07, 2010 at 3:53 PM
Well I've installed as per above with the diodes and it works perfectly at last! I used the blue / YELLOW wire to the CL relay in the end - not sure if the RED / yellow one would work too.
I did try it without the diodes and it just didn't work. I'm not sure if you could pulse positive for unlock/lock - I've only ever used pulse negative before and that's all wiring info. I have looked at says.
I should add that this mr2 turbo is a Japanese import and I have found in the past that much of the wiring is inconsistent with the schematics for the US turbo. Wiring for non-turbos/euro models is different too.
The alarm is an ebay jobbie, it's an "FM 2-way pager":
https://#.co.uk/ws/eBayISAPI.dll?ViewItem&item=360185185163
(Item number 360185185163 if link doesn't work)
The door outputs are simple relays, 6 wires in total, 2 of which (NC) are not used. NO are connected to the lock/unlock wires and commons are connected to ground.
Posted By: tedmond
Date Posted: April 07, 2010 at 4:08 PM
hey howard, some jap cars use 2 wires for unlock. one is unlock itself and one is the lock detection wire where it will sense a key. on the new hondas, you need to diode isolate the wires just like this car i assume.
------------- Ted
Compustar Expert
Posted By: howie ll
Date Posted: April 08, 2010 at 2:28 AM
Priority unlock back in 92? Also keysense hasn't been mentioned, all I can repeat is that I've done 2 dozen, many were imports, never needed diodes.
