2006 equinox, remote starter
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=121259
Printed Date: April 03, 2026 at 8:58 AM
Topic: 2006 equinox, remote starter
Posted By: naresh1912
Subject: 2006 equinox, remote starter
Date Posted: April 10, 2010 at 11:55 AM
Hi ,Trying to insiall remote starter on 06 Equinox  but dont seems to work,i follow the wirw info but dont understand the ACC and the ignition need your help fast
Chris
Posted By: kreg357
Date Posted: April 10, 2010 at 12:23 PM
What type R/S unit are you using?
Your car has the PassLock II immobilizer on it.  What bypass are you using?
The car does not use a Start wire from the R/S unit.  Instead the engine starts cranking after it sees IGN and ACC go positive 12v and then ACC drops to 0 v.  This timing is critical and some R/S units don't bring up IGN and ACC exactly together.
Date Posted: April 10, 2010 at 12:47 PM
I  am using pro start  3471
Chris
Posted By: kreg357
Date Posted: April 10, 2010 at 1:23 PM
Did you use a Passlock bypass module?  I am pretty sure you have the PassLock II immobilizer.
Check the ignition cylinder for a group of 3 wires.  They are usually White or RED / White, Yellow, and Black or ORANGE / Black.
Your ProStart will directly interface any of the major 3 manufacturers, DEI, Fortin or ADS iDatalink.  The bypass is required to make the car think there is a key in the ignition during R/S.  My preferrence would be the ADS TBSL-PL module.
Here is another site for wiring info:   https://www.bulldogsecurity.com/bdnew/vehiclewiringdiagrams.asp
Date Posted: April 10, 2010 at 1:49 PM
Hi Thanks for the reply but do i have to do the relay diagram for the ACC and Ignition or not plese tell me what i have to connect and i have the passlock2 Bypass
Chris
Date Posted: April 10, 2010 at 2:06 PM
hi The battery die out on me reset the passlock and now car wont start now
Chris
Posted By: kreg357
Date Posted: April 10, 2010 at 2:15 PM
+12 volt constant         2 RED / White wires               at ignition switch / steering column
IGN1                              Pink                                          at ignition switch
ACC1                             Orange                                    at ignition switch
ACC2                            Brown                                       at ignition switch
Keysense                    Light Green                              at BCM - Gray 24 pin plug   or  at ignition switch  ( must use )
Passlock wires       can also be found at BCM in 16 pin Gray Plug ( plug on left side, closest to steering wheel )  Yellow and ORANGE / Black.
If you use GRW to control both the bypass and Keysense, diode isolate each connection.
BCM is below radio, remove bezel.
Posted By: kreg357
Date Posted: April 10, 2010 at 2:21 PM
You could be in short or long tamper mode.  Go to the DEI web site:   https://www.bypasskit.com/product.aspx?productid=41   and download the 556L install manual.  Page 6 explains PassLock II troubleshooting.
Posted By: kreg357
Date Posted: April 10, 2010 at 2:33 PM
I don't believe you will need the delay relays that are mentioned on the Bulldog site.  You R/S should work OK without them.
Date Posted: April 10, 2010 at 3:53 PM
Hi I Reset  passlock2 sysyem and the theft light on dash stop flashing so i switch ign off for 10 sec try to start car crank but dont turn over and no theft light flashing just cor wont start (please help me)
Chris
Posted By: tedmond
Date Posted: April 10, 2010 at 6:15 PM
car wont start with key or wont remote start?
if it doesnt start with the key, its time to check all wires at the ignition cylinder if they are loose.
if the car cranks duing rs but doesnt start, it can be a bypass issue OR an ignition wire isnt being powered.
where abouts in ontario ?
Ted
Compustar Expert
