keyless entry, 94 mazda b4000
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=121433
Printed Date: April 30, 2026 at 2:40 AM
Topic: keyless entry, 94 mazda b4000
Posted By: larryf
Subject: keyless entry, 94 mazda b4000
Date Posted: April 20, 2010 at 7:37 AM
need to hook up wires for keyless entry on mazda b4000 1994. what color and where is wire to horn and parking lights?
go rangers
Posted By: kreg357
Date Posted: April 20, 2010 at 8:18 AM
According to Bulldog Security...
Parking Light is Brown (+) at headlight switch or fuse box.
The horn is found in the steering column as follows:   YELLOW/LIGHT GREEN(-) is found on vehicles WITH FACTORY CRUISE CONTROL
and  BLUE(+) is found on vehicles WITHOUT FACTORY CRUISE CONTROL.
Check with DMM because the Ford Ranger is the same vehicle and the Blue wire listed for it is (-).
Posted By: larryf
Date Posted: April 21, 2010 at 8:41 AM
i am installing an astra 50 keyless entry system in a 1994 mazda 4000 pickup .in the instructions it says that i need to add a relay if my parking lights are above 10a, they are 15a. also on the hornthe output is (-)500ma and i need a relay to hook this to the horn. i need wiring diagrams for this. i am new at this and would appreciate any help you could supply .thanks in advance.
go rangers
Posted By: tedmond
Date Posted: April 21, 2010 at 7:50 PM
if the wire is negative, you dont need a relay. if its positive polarity, you need a relay to convert polarity from neg to pos.
your parking lights draw 15amps when they are on? are you testing properly or did you just use the parklight fuse to determine it was 15 amps?
Ted
Compustar Expert
Posted By: larryf
Date Posted: April 21, 2010 at 10:21 PM
thanks. i will try this tomorrow.
go rangers
