progressive door lock
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=121627
Printed Date: April 01, 2026 at 9:27 PM
Topic: progressive door lock
Posted By: flynelf
Subject: progressive door lock
Date Posted: May 01, 2010 at 9:49 PM
I have installed a clifford 590.2x in a 1989 nissan pickup. I have shaved door handles and was using the negative door lock trigger to activate my actuators. I read that you can program a progressive door unlocking function where the driver doors unlocks first and then the passenger when the unlock button is pressed again. The question i have is which wire controls the 2nd unlock trigger? I can use one of the aux inputs to unlock the 2nd door but i don't really want to. in Vipers 5902 manual it refers to a light blue 2nd unlock trigger wire but there is not one on the clifford model that i can find. Do i need to add an extra module? any help would be appreciated. Thanks
Posted By: howie ll
Date Posted: May 02, 2010 at 2:28 AM
You're correct and for reference, it's the same as it's Viper 5902 sibling. Why they left it out is beyond me, you will have to use one of your aux OUTPUTS, please get your terminology correct, that could be an expensive mistake dealing with diodes and relays.
Posted By: flynelf
Date Posted: May 02, 2010 at 3:00 AM
Thanks for the reply, I was hoping there was a way to use the progressive unlock.
Posted By: flynelf
Date Posted: October 06, 2010 at 6:44 PM
I found you could program any of your aux channels to a 2nd lock output by using the bitwriter.
Posted By: t&t tech
Date Posted: October 06, 2010 at 9:29 PM
Yes you're correct, u beat me to it. Bet ya learned something new there howard!
Posted By: howie ll
Date Posted: October 07, 2010 at 12:01 AM
Really my young colonial? Look at my post back in May.
Posted By: t&t tech
Date Posted: October 07, 2010 at 5:36 PM
sorry howie!
