01 lincoln navigator keeps falsing
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=121803
Printed Date: May 02, 2026 at 12:21 PM
Topic: 01 lincoln navigator keeps falsing
Posted By: kiteman
Subject: 01 lincoln navigator keeps falsing
Date Posted: May 12, 2010 at 3:48 PM
I have installed a Viper 350 hp into a 01 Lincoln Navigator..  the customer says that the alarm keeps going off about 20 mins after he gets out an arms it and it does it all night long.. It is giving a zone 4 code which is for the aux sensor, which I did install a glass sensor on, but I have unpluged that from the alarm and we still get the problem.. I went back and checked the door lock system, as these do that power down and they need to be woke (Awaken) whatever you want to call it.. that seems to be right to dei..  I'm stuck and could use some help...  anyone have any suggestions
Posted By: blanx218
Date Posted: May 12, 2010 at 7:57 PM
Did you diode isolate the door triggers?
