2003 dodge ram parking lights
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=121929
Printed Date: May 01, 2026 at 7:16 PM
Topic: 2003 dodge ram parking lights
Posted By: CutDog504
Subject: 2003 dodge ram parking lights
Date Posted: May 20, 2010 at 7:18 PM
I used to do tons of installs years ago, but have been "out of the game" for about 3 years now. But I'm doing a remote start on a 2003 Ram for someone and I can't remember about the parking lights. All the diagrams say to grab them at the switch and use a 330ohm resistor. But if my memory serves me right, I used to grab them under the hood as a positive wire and no relay or resistor was needed. Does anyone know about this? If so, where and what color wire is it?
Posted By: sean11901
Date Posted: May 20, 2010 at 7:41 PM
if this is the full sized 2003 dodge ram pickup...
PARKING LIGHTS ( + )  BLACK / YELLOW (+)  @ RELAY UNDER HOOD, at POWER CENTER
Date Posted: May 20, 2010 at 7:42 PM
PARKING LIGHTS ( - )  PURPLE / YELLOW (-) See NOTE *1  @ BACK of HEADLIGHT SWITCH on Dash
sorry heres the note....
NOTE *1 the (-) Negative PARKING LIGHTS on this vehicle will require a (-)Negative thru a 330 or 1400 Ohm Resistor and an extra Relay part #775, to connect, See DIAGRAM
Date Posted: May 20, 2010 at 7:47 PM
so you will have to wire a relay like this..
85- (-) output from mod
86- (+) 12v Fused
30- This is going to go to the Parking light (-) wire in the back of the headlight switch with the 330 Ohm resistor
87- (-) Grounded
Date Posted: May 20, 2010 at 7:50 PM
if the Mod puts out a (+) signal then..
pin 86 will be the output from mod
pin 85 will be grounded along with 87 together
Posted By: blanx218
Date Posted: May 20, 2010 at 8:33 PM
if using the negative parking lights you will actually need to isolate the wire. cut the purple / YELLOW and wire relay as follows
pin 87 connect to ground with your 330 or 1.4k ohm resistor inline
87a  switch side of purple / YELLOW
30 car side of pur/yel
85 parking light output from remote start
86 +12V or ground depending what type of output comes from the r/s
Date Posted: May 20, 2010 at 10:08 PM
thanks for the correction.. :-)
Date Posted: May 21, 2010 at 2:28 PM
I know about the resistor and relay method. What I was asking is isn't there a positive wire under the hood where you can tap in and no extra relays or anything is needed?
Posted By: blanx218
Date Posted: May 21, 2010 at 9:23 PM
yes there is. its at the PCM which i think is on the drivers side fender well
Posted By: blanx218
sorry. forgot to say its BLACK / YELLOW
