how to turn on heated seats
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=122225
Printed Date: May 02, 2026 at 7:27 PM
Topic: how to turn on heated seats
Posted By: jimmeezgolfvr6
Subject: how to turn on heated seats
Date Posted: June 09, 2010 at 6:02 PM
i have a 2006 mini cooper s with a compustar alarm and remote start installed. anyone know how to activate the heated seats upon remote start? it doesn't appear that it's a straight-forward apply +12v or ground to a particular wire....
any help would be greatly appreciated. thanks in advance
all problems can be resolved with a hammer
Posted By: i am an idiot
Date Posted: June 09, 2010 at 7:34 PM
Can you get to the harness at the seat?  Can you tell how many wires go to the heater?  How many settings does it have per seat?
Date Posted: June 09, 2010 at 8:04 PM
the harness at the seat has 3 wires that closely match those coming from the switch. the switch has a total of 5 wires, 3 of which appear to be the same wires at the seat harness based on their colours and thickness. 1 is GREEN/ purple (16 ga), 1 is brown (20 ga), and 1 is GREEN / WHITE (20 ga).
the GREEN/ purple appears to be the one that i want, based on it testing +12v when pressing the switch, but it only shows +12v for a few seconds at most, and does that for both high and low settings.
the switch as 3 settings:
- 1st press turns on high pwr
- 2nd press switches to low pwr
- 3rd press switches back to off
the switch is non-latching, you can tell which setting you've reached from the lights on the switch that turn on or off.
Date Posted: June 09, 2010 at 8:22 PM
With the seat on low, test the voltage on the GREEN/ purple wire, but this time place the black meter lead on the other 2 wires that go to the heater.  One at a time of course.  Try the seat on both setting also.
Posted By: howie ll
Date Posted: June 10, 2010 at 3:13 AM
I think you will have to go to a wire actually at the seat, the switch will go to an ECU where the "latching" will take place. This is where you need a wiring diagramme.
Date Posted: June 10, 2010 at 7:40 PM
thanks for your input guys, i guess i'll have to figure it out for myself on this one.
Posted By: topinstaller200
Date Posted: June 11, 2010 at 2:02 AM
It SUMMER
Posted By: lectricguy
Date Posted: June 12, 2010 at 7:29 AM
jimmeexgolfver6-
  If the seat heater switch is momentary, you can usually control the seat from the switch wire.  Haven't done mini seats, but I have done others.
You will usually see 5 wires--these are something like:
Switch illumination
Actual seat heater switch output (pulses to ground as swtich is pressed)
high indicator
low indicator
ground
I would remove the switch, and probe the swicth wires with a multimeter or test light to find the actual switch ouput, which should show as a ground pulse during switch depression.   For remote start, this is the wire you would use to activate the seats.  If you want to hook up both seats, you wold locate this wire from both switches and diode or them together -- make a "y" with 2 general purpose diodes, connecting the bands together in the Y,  The individual diodes connect to the seat switches, the common to the Remote Start control.
Lectric Guy
Posted By: catback
Date Posted: June 12, 2010 at 8:13 AM
topinstaller200 wrote:
It SUMMER
Ur right it IS. Heated seats in the winter is ok but SUMMER?
Posted By: chev104275
Date Posted: June 12, 2010 at 10:52 AM
i much rather install in the summer than the winter so why not do it now
Date Posted: June 12, 2010 at 4:10 PM
lectricguy:
thanks for the additional help. i will give it a shot and see if i'm successful. just out of curiousity, what car(s) are you referring to that use this type of switch?
topinstaller200:
maybe you didn't notice that i'm from canada.....we all live in igloos here!
