alarm/remote start 2011 scion xb
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=122312
Printed Date: April 02, 2026 at 6:01 PM
Topic: alarm/remote start 2011 scion xb
Posted By: staticlink05
Subject: alarm/remote start 2011 scion xb
Date Posted: June 15, 2010 at 1:44 PM
Hello family!
i have a new 2011 scion xb for my wife.
and i want to install the Viper 5701P alarm and remote start system in the car .
i have found the wiring diagram for the 2008 model xb but i just wanted to know if it would be the same for the new 2011?
or if there is a new updated diagram for the 2011 scion xb?
thank you in advance!
Posted By: chev104275
Date Posted: June 15, 2010 at 7:46 PM
This is all i have but it should be close if not the same
2010 SCION XB 4DR SUV WITH 2.4L ENGINE AND STANDARD AUDIO SYSTEM
Security
WIRE COLOR POLARITY LOCATION
Battery WHITE (+) IGNITION SWITCH HARNESS
   THIS WIRE IS FUSED AT 30 AMPS
Ignition 1 GRAY (+) IGNITION SWITCH HARNESS
Starter 1 WHITE (+) IGNITION SWITCH HARNESS
All Door Trigger
   USE EACH DOOR TRIGGER AND DIODE ISOLATE EACH WIRE
Domelight Super WHITE (-) AT VEHICLE FUSEBOX
LF Latch WHITE (-) IN PLUG AT VEHICLE FUSEBOX
RF Latch BROWN (-) IN PLUG AT VEHICLE FUSEBOX
LR Latch LIGHT BLUE (-) IN HARNESS IN DRIVER KICKPANEL
RR Latch LIGHT GREEN (-) IN PLUG AT VEHICLE FUSEBOX
Trunk Trigger LIGHT GREEN (-) AT VEHICLE FUSEBOX
Parking Lights GREEN (+) AT VEHICLE FUSEBOX
Low Crr Pk Lights WHITE (-) AT VEHICLE LIGHT SWITCH HARNE
Convenience
Trnk Release ORANGE (-) IN HARNESS IN DRIVER KICKPANEL
Remote Start
Ignition 2 WHITE (+) IGNITION SWITCH HARNESS
Accessory 1 BLACK (+) IGNITION SWITCH HARNESS
Starter 2 WHITE (+) IGNITION SWITCH HARNESS
Key Sense BLUE (-) AT VEHICLE FUSE BOX
   THIS WIRE WILL DISARM THE FACTORY ALARM WITHOUT UNLOCKING THE DOORS
Tachometer GRAY (AC) AT DATA LINK CONNECTOR
Crankshaft Sensor WHITE (AC) AT ECM MODULE BEHIND GLOVEBOX
Camshaft Sensor BLACK (AC) AT ECM MODULE BEHIND GLOVEBOX
Speed Sense VIOLET (AC) AT RADIO HARNESS
   ALSO AT ECU MODULE BLACK 60 PIN PLUG PIN 8
Low Crr. Pk Lights WHITE (-) AT VEHICLE LIGHT SWITCH HARNESS
Brake Lights BLUE (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Lights RED (+) AT INTERIOR FUSE BOX - TOP LEFT CORNER
Horn LIGHT GREEN (-) IGNITION SWITCH HARNESS
   ALSO AT VEHICLE FUSEBOX
Rear Defrost BLACK
Modules
WIRE LOCATION
Module 1 ECM MODULE - UNDER HOOD BETWEEN AIR CLEANER AND FUSE/RELAY BOX
Module 2 SKID CONTROL MODULE - UNDER HOOD NEAR BRAKE BOOSTER
Doorlocks/Windows
Power Unlock PINK (-) IN HARNESS IN DRIVER KICKPANEL
   TEST THIS WIRE WHILE TURNING THE KEY IN THE DRIVER DOOR CYLINDER, THIS WIRE REQUIRES A DOUBLE PULSE
PowerLock LIGHT BLUE (-) IN HARNESS IN DRIVER KICKPANEL
Driver Mtr Unlock ORANGE (AC) AT DRIVER DOOR LOCK MOTOR
Driver Mtr Lock LIGHT GREEN (AC) AT DRIVER DOOR LOCK MOTOR
Pas Mtr Unlock LIGHT BLUE (AC) AT PASSENGER DOOR LOCK MOTOR
Pas Mtr Lock RED (AC) AT PASSENGER DOOR LOCK MOTOR
LF Window Up PINK (REV) AT DRIVER WINDOW SWITCH
LF Window Dn WHITE (REV) AT DRIVER WINDOW SWITCH
RF Window Up GREEN (REV) IN HARNESS IN DRIVER KICKPANEL TO DOOR
RF Window Dn BROWN (REV) AIN HARNESS IN DRIVER KICKPANEL TO DOOR
LR Window Up RED (REV) IN HARNESS IN DRIVER KICKPANEL TO DOOR
LR Window Dn BLUE (REV) IN HARNESS IN DRIVER KICKPANEL TO DOOR
RR Window Up GREEN (REV) IN HARNESS IN DRIVER KICKPANEL TO DOOR
RR Window Dn BROWN (REV) IN HARNESS IN DRIVER KICKPANEL TO DOO
