dealing with pulses?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=122356
Printed Date: April 03, 2026 at 7:20 AM
Topic: dealing with pulses?
Posted By: choleaoum
Subject: dealing with pulses?
Date Posted: June 20, 2010 at 1:36 PM
Hey guys, I'm swapping out my cluster for a G37 cluster because it looks so much better but I'm having an issue regarding the speedo.
It appears that the G35 uses a 2 pulse speed signal, and the G37 uses an 8 pulse speed signal. Would anyone here have some insight on how to deal with it?
Thanks guys! I know many of you here are guru's at this kind of stuff lol.
Posted By: i am an idiot
Date Posted: June 20, 2010 at 3:14 PM
Usually the information they give you is the number of pulses per a given distance.  Short of adapting the device that generates the pulses, I really see no way you will be able to pull this off.
Posted By: oldspark
Date Posted: June 20, 2010 at 10:59 PM
Division is easy.
Multiplication difficult - except sometimes x2 where you edge-trigger each pulse.
Above that gets messy if evenly spaced pulses are required. In old days PLLs (Phase-Lock Loops) were used; these days digital.
If spacing is not a problem, have each edge trigger two pulses, hence 2 pulses becomes 8.
Otherwise find out what is supplying the pulses and maybe modify that.
Date Posted: June 22, 2010 at 4:07 PM
oldspark wrote:
Division is easy.
I was thinking the same thing, I'm not too sure if a gap would effect much but it's worth a shot. How would I get it to trigger 2 pulses each?
Posted By: oldspark
Date Posted: June 22, 2010 at 6:13 PM
Calc your max speed and hence max pulse rate and have each edge trigger a 2-shot pulser...
Though it's easier following the first edge-trigger with a second where each edge-triggered output is less than the max (speed) pulse rate duration (draw the pulses and figure it out).
IE - the single original pulse feeds a +ve edge trigger and a -ve edge trigger (hence x2 pulses). Each of those feeds another + & - edge trigger (another x2). All outputs are combined (ie, OR'd - if parallel circuits) and must be adequately spaced to get x2x2 = x4 pulses from the original 1 pulse.
Or maybe use a clock at twice the max pulse rate to clock a 4017 counter set to count to 4... (leave "0", diode-OR outputs 1,3,5,7 together, "8" to reset, and need speedo pulses to trigger one sweep per pulse..... (sorry, just thinking aloud but with zero ROM)
