momentary switch, multiple functions?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=122452
Printed Date: April 06, 2026 at 6:07 AM
Topic: momentary switch, multiple functions?
Posted By: 543sp
Subject: momentary switch, multiple functions?
Date Posted: June 28, 2010 at 6:00 AM
make a Momentary switch have multiple functions using only relays to power 12v actuator for example first push first relay powered second push first relay off second relay on third push second and first relays off third relay on and so forth then with a second momentary switch perform the sequence in reverse
thanks for help in advance
Posted By: i am an idiot
Date Posted: June 28, 2010 at 9:27 AM
I know it is not a momentary pushbutton, but this is the only thing that I can think of that may meet your criteria.
https://www.radioshack.com/product/index.jsp?productid=2062536
Posted By: howie ll
Date Posted: June 28, 2010 at 4:54 PM
Talk about old school Mr. I we were wiring up demo stands with those in 1973.
Date Posted: June 28, 2010 at 6:49 PM
I was adding crystals to CB radios with that switch at about that time.  From what I read from his requirements, that switch will be perfect, short of the bling factor he may want.
Posted By: oldspark
Date Posted: June 28, 2010 at 8:21 PM
I was dimming fluorescent lights around then....
Posted By: 543sp
Date Posted: June 29, 2010 at 3:14 AM
so by the sound of it, it can be done but how is it done ?
Posted By: oldspark
Date Posted: June 29, 2010 at 3:37 AM
By adding together successive functions - latching, flip-flops etc.
What can be done in modern "logic" circuits can be done with relays - it's just that few people do it that way any more (relays replaced by valves replaced by transistors replaced by VLSI (chips etc); these days PICs else older discrete logic chips).
Logic Tables (Boolean Algebra; state tables/diagrams) help the circuit simplification, but might drive you nuts in the process. (It did me!)
Posted By: 543sp
Date Posted: June 29, 2010 at 5:28 AM
a diagram would be of good use
Posted By: howie ll
Date Posted: June 29, 2010 at 11:26 AM
Wouldn't these diagrammes be chargeable as they are your intellectual property Mr. Oldie?
Posted By: oldspark
Date Posted: June 29, 2010 at 11:40 AM
LOL!
And here I thought it was someone asking the OP for diagrams....
At this stage I wouldn't charge for the IP, but I'd charge for tuition!
I could post a diagram of a PIC.....
