2005 tacoma key program
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=122726
Printed Date: April 29, 2026 at 8:43 AM
Topic: 2005 tacoma key program
Posted By: gtfallman
Subject: 2005 tacoma key program
Date Posted: July 17, 2010 at 7:03 PM
do anyone know how to program a new transponder-chip key on 2005 tacoma, without having the use of master key. Master key has been stolen.
Posted By: tedmond
Date Posted: July 17, 2010 at 10:59 PM
the fortin bypass modules will program with the valet key as well.
as far as programming a new key, the dealer can do it without any problems ------------- Ted
Compustar Expert
Posted By: Mike M2
Date Posted: July 18, 2010 at 3:18 PM
It won't work. They cannot program a chip key from a valet key, period. You must have a black head key to start with...
------------- Mike M2
Tech Manager
CS Dealer Services
Posted By: tedmond
Date Posted: July 20, 2010 at 2:52 PM
if you have a valet key but still have the silver metal tag with 5 digits, they can cut a new master key for you.
------------- Ted
Compustar Expert
Posted By: Mike M2
Date Posted: July 20, 2010 at 4:35 PM
I may be wrong, but isn't the tag for the cut only? I don't think that has to do with the code...
Tech Manager
CS Dealer Services
Posted By: tedmond
Date Posted: July 23, 2010 at 5:35 AM
from what i know, the metal tag is a verification number used to cut a new master key. They punch the number in their computer and the new immobilizer code is issued.
this is what i heard from the tech when i got another master key cut. ------------- Ted
Compustar Expert
Posted By: Mike M2
Date Posted: July 23, 2010 at 6:06 AM
I talked to a buddy at a dealer i work with, he said on the Taco if you have zero master keys you need replace the immobilizer ECU at 350 bucks, then code two new keys as it has to see two master codes. He said not all Toyotas code the same way tho...
Tech Manager
CS Dealer Services
Posted By: tedmond
Date Posted: July 25, 2010 at 12:01 PM
wow, good thing i havnt lost any more keys. just that one time. Its ridiculous what the keys go for!
what happened to 5 dollar keys ? now its 300+ Sure its to prevent theft, but the technology is just costly for replacement parts. ------------- Ted
Compustar Expert
Posted By: Mike M2
Date Posted: July 27, 2010 at 6:17 PM
I hate this too. Gotta love GM coding, one key for 35 bucks and all you need is one other key to program the new one yourself. Drawback is a valet could make a copy. I think Ford does it best, all Fords are the same since 2003 and you need 2 to program but at least you can do it yourself...
Tech Manager
CS Dealer Services
Posted By: tedmond
Date Posted: July 27, 2010 at 6:58 PM
mike, does that include aftermarket blank keys? or do you need a locksmith with a programmer?
------------- Ted
Compustar Expert
Posted By: Mike M2
Date Posted: July 28, 2010 at 7:02 PM
We have issues with blanks at Carmax all the time. They are really clone keys that just duplicate the existing coded key, so they won't work as a second key. Because of this, you need a programmer to use one unless it's the 3rd key and you already have 2 factory ones. Carmax will sell a car with one factory key then get a guy to clone a second aftermarket key so the customer has 2, then expect us to install a remote start using an Idatalink bypass. It simply won't work because the codes are the same and it thinks it is seeing the same key twice...
Tech Manager
CS Dealer Services
