2003 ford escape bypass
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=122733
Printed Date: May 16, 2026 at 9:41 AM
Topic: 2003 ford escape bypass
Posted By: nick520
Subject: 2003 ford escape bypass
Date Posted: July 18, 2010 at 1:54 PM
I have a 2003 Ford Escape that I'm going to put a 2-way remote start system on and I was told that I need a DEI 555S bypass module. Is this correct? Is that the right model if I do in fact need one? When I looked that part number up it said it was for only a 2001 Ford Escape. Does it work on both? Any advice helps! Thanks.
Signed, Sir Nicholas
Posted By: kreg357
Date Posted: July 18, 2010 at 2:39 PM
Yes, the 555SW will work.  However there are better ( more reliable ) bypass units available.  With the 555SW, placement of the transponder "pill" is critical.  Some trial and error is involved and the the "pill" should be mounted in position very securely.   Additionally, if you live in an area where it gets cold, the 555SW type bypass units can be affected by the cold and work intermittantly.
I would recommend something like a PKFM or PKALL.  They connect directly to the cars wiring and are very reliable.  Here is a link to DEI's bypass modules: https://www.xpresskit.com/VehicleCompatibility.aspx?p=-1&year=2003&make=Ford&model=Escape&ps=1&s=0   There are units available from Fortin ( https://ifar.ca/en/vehicles/ford/escape/2003/ ) and iDatalink  ( https://www.idatalink.com/helpdesk/ ) that are very good also...
Either way you go, you will need two working, non-clone, keys to program the bypass to the car.
Good luck
Posted By: Mike M2
Date Posted: July 18, 2010 at 8:07 PM
I agree, the 555sw is a real POS and unreliable. Use a hardwire type bypass, like this
https://store.idatalink.com/index.php?l=product_detail&p=35
Mike M2
Tech Manager
CS Dealer Services
Posted By: smokeman1
Date Posted: July 19, 2010 at 11:52 AM
I have used the Fortin brand with very good results.
