2007 dodge nitro remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=122748
Printed Date: May 16, 2026 at 1:50 AM
Topic: 2007 dodge nitro remote start
Posted By: jpadj22
Subject: 2007 dodge nitro remote start
Date Posted: July 19, 2010 at 1:49 PM
Hi everyone, ijust got a dodge 2007 nitro for my wife and she asked me if could install a remote start. i have done remote starts before so im not so cluless about them but this one is a little more advance for my skills. can anyone tell me whats the best way to install it ? and whats the best remote start i can get for a decent price..thanks
Posted By: kreg357
Date Posted: July 19, 2010 at 6:34 PM
All depends on what she wants.  One way, two way, LCD FOBs?
My choice for a good R/S at a reasonable price would be an Ultra Start U1272XR PRO.  Cost is about $60.  It is a one way with decent range and nice FOBs.  Here is a link:   https://www.ultrastarters.com/Feature_Sheets/PRO_Feature%20Sheets%20PDF/1272XR-PRO.pdf  Feature programming can be done with the remotes easily.
The more important item is the bypass.  My choice would be the ADS iDatalink ADS AL-CA with the ADS AL(DL) CH5 firmware.  Cost is about $60.  This one module will do a lot for you especially if your Nitro has the factory alarm.  Here is a link :  https://store.idatalink.com/index.php?l=product_detail&p=20  Download the CH5 install guide to see the items supported and the wiring necessary.
Both items can be found on EBay or Google them.  Remember that the iDatalink module comes with no firmware loaded so get it from a dealer that will flash it with the CH5 firmware for you before shipment.
Good luck.
Posted By: jpadj22
Date Posted: July 19, 2010 at 7:52 PM
Thanks for answerin kreg so that moduel would be the only one i need then?
Posted By: kreg357
Date Posted: July 19, 2010 at 8:45 PM
The iDatalink module is controlled by the remote start unit and will take car of the cars ignition immobilizer, door locks, trunk and alarm system all thru 4 wire connections to the car.  It will also supply the remote start the tach and brake pedal signals.
The remote start brain will still need to be connected to cars +12v, ground, horn, hood trigger and  parking lights ( along with all the connections to the ADS AL-CA module detailed in the iDatalink CH5 install guide ).
Additional parts you will need:   some 8 amp diodes,  a 1 amp diode and a inline fuse holder with a 5 amp fuse.
There are other good remote start units and some bypass modules that will also work.  My suggestion is based on price, availability, ease of install, features, ease of programming and reliability.  Remember that all the high end remote start companies ( DEI, Compustar, Ultra Start  etc. ) offer a life time warranty "if and only if" it is installed by a authorized dealer.  Also getting tech support from the manufacturer is only available to authorized dealers.
Here is a link to Bulldog Security for the wiring list:  https://www.bulldogsecurity.com/bdnew/vehiclewiringdiagrams.asp
Posted By: jpadj22
Date Posted: July 20, 2010 at 7:37 AM
thanks kreg u been a very big help i will order the moduel and the remote start today.
