viper 5701, 2004 kia sorento
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=122749
Printed Date: May 16, 2026 at 12:58 AM
Topic: viper 5701, 2004 kia sorento
Posted By: charlie9469
Subject: viper 5701, 2004 kia sorento
Date Posted: July 19, 2010 at 2:51 PM
Hello, I just bought the Viper 5701 and i am about to install it into a 2004 kia Sorento. If any of you have any advice or tips please let me know. My sorento has a manual transmission and i am trying to put the remote start. I read it is possible with the Viper 5701. Thanks before hand. Any advices or tips will be greatly appreciated.
Date Posted: July 19, 2010 at 2:56 PM
Hello again...if any of you are familiar with the viper 5701 on a kia sorento can you please tell me what cables do i really need and which ones i dont? thanks.... advice and tips are welcome!
Posted By: tedmond
Date Posted: July 20, 2010 at 2:47 PM
time to pull up a wiring guide and the wire guide for the unit. match the wires you need from the car wires to the unit wires.
That will help you eliminate wires you dont need. Pull out a DMM (multi meter) and start testing wires to see if they are correct.
Connect and solder all wires.
Ted
Compustar Expert
Date Posted: July 20, 2010 at 5:49 PM
Tedmond....Thanks for your tips I just got a tech sheet for the sorento i hope this would do it... Thanks
Date Posted: July 23, 2010 at 1:26 AM
Ok I got to install the viper 5701 in my sorento and everything seems to be working ok except the remote start and the trunk/ hatch release. I gave up on the remote start...but if anyone knows how to install it on a sorento (manual transmission) please give me some tips. Now i really would like to use the trunk release feature. I connected the red with white wire from the H1 (which is the trunk/hatch release wire) into a red with orange wire in the ETACS 14PIN PLUG,PIN 3 (which is below the radio) which is according to a tech sheet is the TRUNK/HATCH RELEASE wire for the sorento. This wire has a negative polarity. The release trunk/hatch feature is not working even though i connected these wires. If anyone knows if i need to connect something else to get the trunk/hatch release feature working please let me know. Thank you
Posted By: t&t tech
Date Posted: July 23, 2010 at 5:36 PM
Have you tested the wire to verify? Also have you made the remote start connections? If so, what happens when you try to remote start?
Date Posted: July 23, 2010 at 6:06 PM
t&t tech,
I did connect the remote start and when i try to turn it on the remote gives me an error beeb and the parking lights flash 7 times. According to the diagnostics that means " Manual transmission mode is enabled and not initialized. Ok let me tell you how I connected the remote start. You tell me if i did something wrong or if i need something. First the neutral switch grounded it to the chassis. Second.. on the " Heavy Gauge, 10-pin connector (H3) I did the following connections.
1.pink (Ignition 1 input/output) = to the yellow cable on the ignition harness
2. RED / white (+) 30a fused ignitio 2/flex relay pin 87 input = I did not use the sorento does not have a 2nd ignition
3.Orange (Accessory output)= Did not use
4. Violet ( Stater output) = Connected to the red starter wire (+) on the ignition harness
5. Green (Stater input) = Did not use i have no idea where this goes, the tech sheet only gives me 1 stater wire in the sorento which is the red one.
6. Red (30 amp fused Ignition 1 relay input)= Did not use have no idea where it goes
7. Ping/white ( Ignition 2 flex relay output) = Did not use have no idea where it goes
8.Pink/black (87a of Ignition 2/flex relay) = Did not use have no idea where it goes
9. RED / Black (30a fused accessory/starter relay input) Did not use have no idea where it goes.
That is what i connected.. I did connect the tachometer wire and i was able to learn the tach signal. I also connected the brake wire and the hood pin. I am new at this so any help will be gladly appreciated.
On the Trunk release issue that RED / orange cable goes all the way to the door button that releases the trunk hatch. However in that button there are 3 more wires. 1 black and 2 red ones and the RED / orange wire.
Thanks and i hope you can help me out.
Posted By: dasbogie
Date Posted: July 23, 2010 at 9:14 PM
Your red,RED / white,and RED / black all need to go to constant 12 volts which are your green and blue wires at the ignition switch.  Viper orange needs to connect to vehicle orange and viper pink/white needs to connect to vehicle white.  If you want starter kill you have to cut the vehicle starter wire and connect green to key side and purple to vehicle side.  You can omit the pink/black as it does not apply to your situation.  Do test the vehicle wires before connection to verify function.  Bulldog lists the trunk pop as needing a relay.  It also lists that wire in the driver kick panel.  Once you get these wires connected, you have to perform the shutdown sequence in order to get it to remote start.  If you do not have the full manual for the 5701 it is available in the downloads section of this site.
Advanced
Date Posted: July 23, 2010 at 11:20 PM
dasbogie,
I connected everything like you said for the remote start and it still does not work. :( It gives me an error beeb on the 2-way controller followed by the seven flashes of the parking lights.I tried the shutdown process still no success! Any more hints are appreciated. Thanks!
One more thing.... for the neutral switch in the installation guide it says that i can be grounded for automatic transmission and for manual ones you can put it in the hand brake/emergency brake. I have a manual transmission and i grounded the neutral switch. Do you think i have to connected to the emergency/hand brake? Do you think that can be a factor?
Posted By: dasbogie
Date Posted: July 24, 2010 at 7:05 AM
you could try the sequence again starting with the nss to off position.  in the sequence when it calls for parking brake, you could just flip the switch to on.  is your door trigger wire connected?
Advanced
Posted By: howie ll
Date Posted: July 24, 2010 at 9:53 AM
Transponder by-pass anyone?
Tach programmed?
The difference between amateurs and pros.
They (the amateurs) assume and we test.
Please run that NSS to the parking brake, at least it makes ME feel safer.
Date Posted: July 24, 2010 at 11:04 AM
dasbogie, I tried putting the nss into the off position and we are making progress. Ok at least i can activate the remote start but when i want to turn the car on it wont start. I can see the cluster moving and the viper brain trying to start the sorento but nothing happens. This is the sequence i am doing.
(remember i have a manual transmission)
1. Start the car with me inside.
2.engage emergency brake.
3.put the car in neutral.
4. press the break pedal.
5. turn the nss switch to On position.
6. release break pedal.
7. press the remote start button on the remote (green light comes on and chimes)
8. remove key (car is still on and running)
9.exit car
10. arm car (car automatically shuts down)
So I am assuming the remote start was properly activated
now when i try to remote start to turn on the car I press the remote start button on the remote and a green light comes on and a chime and i can se the the viper brain trying to remote start because i can se movement on the cluster , but the cars never starts. I don't think this car has an immobilizer because it did not came with a factory alarm and the key does not has a chip.
Any more advices are greatly appreciated! Thanks dasbogie for your time.
*Yes the tech signal is learned
Date Posted: July 24, 2010 at 10:16 PM
Hello,
I just finished installing a viper 5701 car alarm with remote start. I got everything working so far with help from this forum. The only thing that i need is to bypass the clutch in order for the remote start to work. The remote start activates and everything I only need to bypass the clutch. I have a 2004 kia sorento with manual transmission. If anyone can tell me how to bypass the clutch (what cables do i need to connect to the viper alarm and things like that) i would really appreciated it. This is the only thing i need in order to have remote start. Thank you very much before hand.
Date Posted: July 24, 2010 at 11:57 PM
Ok I was able to do the clutch bypass on a 2004 kia sorento with manual transmission. All I did was to connect the yellow/black wire from the clutch switch into the purple wire (starter output wire on the viper 5701). And that is the clutch bypass. There is no need for a relay.
**Moderators you can close this post everything is resolve!!... :) Thank you!
Posted By: i am an idiot
Date Posted: July 25, 2010 at 9:15 AM
Is the 5701 a manual safe remote start?
Date Posted: July 25, 2010 at 10:48 AM
Yes the 5701 is a manual safe remote start. There is a procedure you have to do every time to activate the remote start. ex. opening a door while putting the handbrake and pressing the brake things like that or else it wont work. :)
