2010 fusion auto door lock on exit
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=123146
Printed Date: May 02, 2026 at 5:35 AM
Topic: 2010 fusion auto door lock on exit
Posted By: montyj
Subject: 2010 fusion auto door lock on exit
Date Posted: August 16, 2010 at 10:17 PM
I need to have the doors autolock upon exiting the vehicle. I don't want to rely on my memory to hit the remote lock. I need it auto'd.
I'd prefer to not install a complete security system, it shouldn't be necessary.
If there is no after market module or system, can someone give me the schematics for the fusion SE?
I can build a delay timer if I can get a hold of the wiring diagrams. All I need is the key "out" of the ignition signal and the Door lock side.
------------- Monty
Posted By: i am an idiot
Date Posted: August 16, 2010 at 10:57 PM
Key Sense |
BLUE/GRAY |
IGNITION SWITCH HARNESS |
When the key is removed from the switch, the positive voltage should go away from this wire. You should check with a meter to verify this.
PowerLock |
BLUE/GREEN |
AT SMART JUNCTION BOX BEHIND DRIVERS SIDE OF DASH ABOVE KICKPANEL |
This requires a negative puse to lock.
Posted By: montyj
Date Posted: August 16, 2010 at 11:30 PM
Just what I needed.
Just a quick question: Does the Blue/Green Power lock do all 4 doors?
------------- Monty
Date Posted: August 16, 2010 at 11:55 PM
Yes, a pulse on this wire will lock all doors.
Posted By: howie ll
Date Posted: August 17, 2010 at 6:31 AM
I might point out that when I enable auto arm AND lock on alarms, I get the customer to sign a release waiver.
There is no such thing as "I will never leave the key in the car".
Posted By: montyj
Date Posted: August 17, 2010 at 8:21 AM
Thanks but that's why I want to use the 'KEY SENSE" line as a must for activation. If the key is in the ignition the doors won't AUTO LOCK or am I missing something? ------------- Monty
Posted By: howie ll
Date Posted: August 17, 2010 at 9:19 AM
Quite right and since I haven't got a clue what a Fusion is, you'll have to find out whether it has one and use that as a relay interlock for the locking.
