need 98 civic hatchback wiring alarm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=12321
Printed Date: April 24, 2026 at 12:41 AM
Topic: need 98 civic hatchback wiring alarm
Posted By: AMANGILL
Subject: need 98 civic hatchback wiring alarm
Date Posted: April 17, 2003 at 9:13 AM
need the hatchback civic wiring diagram and i cant find the dome light wire/ door trigger need help too find the wire where its located? and what color is it ? A.S.A.P
aman
Posted By: drvnbysound
Date Posted: April 17, 2003 at 10:01 AM
The dome light wire is a Light GREEN/ Red (-) wire, its in the 24-PIN blue connector near the top of the fuse box. If you completely removed your factory radio, it will interrupt the dome light circuit, assuming that you had factory keyless entry.
Date Posted: April 17, 2003 at 10:03 AM
If you did have factory keyless entry, and did remove the factory radio. Jumping Pin #8 (Light GREEN/ Black) to PIN #14 (Light GREEN/ Red) will reconnect the dome light circuit.
Good luck with the alarm
Posted By: AngryDomo
Date Posted: May 01, 2003 at 3:09 AM
^^hello, i've just run into the same problem.  this is probably a dumb question but how do I "jump" Pin #8 to Pin #14?  Thanks for your help!
Posted By: Velocity Motors
Date Posted: May 01, 2003 at 11:07 PM
Use a small piece of wire and attach the two wires that are in those locations together with the wire. It will act as a bridge that connects the two wires.
