viper 5902 2004 wrangler
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=123248
Printed Date: April 29, 2026 at 4:06 PM
Topic: viper 5902 2004 wrangler
Posted By: pyr0tek
Subject: viper 5902 2004 wrangler
Date Posted: August 25, 2010 at 12:53 PM
Hiya all. I just picked up the 5902 and planning to do the install within the next week. Have designed/built and installed my car pc from the ground up before, so i'm pretty comfortable taking this on.
Searching on here before I bought this, it seemed like the consensus was zone 4 sensor input could be used without programming via Bitwriter. In the quick reference sheet that is included with the brain, they list the default setting for zone 4 as "Sensor Type: None" and it is a bitwriter-only option.
I have a DEI field disturbance sensor that I was planning on connecting as zone 4. So now i'm a bit confused about the bitwriter requirement. I'm sure one of you could clear up my confusion. :)
Thanks, and I may have a few questions down the line here.
Posted By: pyr0tek
Date Posted: August 25, 2010 at 1:27 PM
One other thing I just noticed. In the wiring guide on here for the 04 Wrangler tachometer, what does "Set 2 Cyl" refer to?
Tach: Blue/Tan [ECM Passenger side Firewall] Set 2 Cyl
Posted By: kreg357
Date Posted: August 25, 2010 at 8:29 PM
I believe the "Set 2 Cyl"  is guidance for a remote start tach configuration setting for a particular brand ( AudioVox ?? ) remote start.  The Tach wire color and location is all you really need.  Most remote starts ( Ultra Start, Compustar, Viper, etc ) will learn the signal OK.
Posted By: pyr0tek
Date Posted: August 26, 2010 at 10:52 AM
Thanks for the reply, that would make sense.
On another note, I was able to find the 5901 install guide on here which is pretty close and a great resource. Sounds to me that the bitwriter is only required to change the ICON for the zone 4 sensor, as long as it's functional it's good enough for me.
