1999 audi a6 remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=123336
Printed Date: April 03, 2026 at 8:03 AM
Topic: 1999 audi a6 remote start
Posted By: jaken1913
Subject: 1999 audi a6 remote start
Date Posted: September 01, 2010 at 3:33 PM
i installed remote start in my car with a security audiovox aps997 when i turn the car off and take the key out the alarm goes off weven with no shock sensor also the remote start button does nothing ive checked my wires 10 times the box makes no noiose of rleays when i hit the remote start also
Date Posted: September 01, 2010 at 5:11 PM
i got rmeote start wokring now but all that happens when i press remote thatrt the relay box under the hood ticks a few times then i get nothing all wires are hooked up right
i mean the alarm relay box not the one under the hood
Posted By: t&t tech
Date Posted: September 01, 2010 at 5:35 PM
Have you any prior experience with installing alarms?
Date Posted: September 02, 2010 at 1:06 AM
yea in many cars i got a new brain for it and it works but now when i turn the car off the alarm goes off for some reason
Posted By: howie ll
Date Posted: September 02, 2010 at 5:24 AM
Factory alarm! Something's triggering it and it brings on the 997. Check the factory unit, also your wiring, you appear to be asking 2 different questions.
Not a car to be working on in fact an electronic nightmare! Your door trigger contacts might need to be taken from the factory lock alarm unit at the rear.
Posted By: howie ll
Date Posted: September 02, 2010 at 5:31 AM
Just realised that your door/trunk/hood triggers should have gone to the module under the carpet on the floor in front of the driver's seat.
Extending the lock pulse should close windows etc.
Date Posted: September 02, 2010 at 10:03 AM
thanks howie ive read were the factory disarm ground is but not a very good given location on the guide
Date Posted: September 02, 2010 at 10:52 AM
the aps997 alarm goes off not the factory
Posted By: howie ll
Date Posted: September 02, 2010 at 10:58 AM
You will have to find out what's triggering it. I looked this vehicle up and Directwire, Audiovox and this site all gave different locations and colours. All incidentally different from what I'm used to on Euro versions.
My though without looking at or trying to judge your install from 3500 miles away would be to look at the locking system and your door/trunk/hood contacts.
Have you set it for double pulse locking/unlock?
Date Posted: September 02, 2010 at 11:02 AM
what do u mean double pules like to put window sup n down?
o and this car is june of 99 so it has 98 a6 wiring instead of 99 wiring
Date Posted: September 02, 2010 at 11:08 AM
the aps997 alarm goes off and also this car is june 99 so it has the 98 wiring in it
Date Posted: September 02, 2010 at 11:09 AM
lol disregard my last post please and thank you!!!
Posted By: howie ll
Date Posted: September 02, 2010 at 11:12 AM
No some of these have priority control, require 2 x 0.8sec (that's your a/vox default) to unlock.
To raise windows you need to EXTEND the lock pulse time wise, e.g. 15 seconds.
Date Posted: September 02, 2010 at 11:16 AM
yea i will make it 15 i still cant figure this thing out its killn! `
Date Posted: September 03, 2010 at 8:17 PM
ok so i guess the alarm goes off non stop after the car is started this is crazyyyyy!!!!
Date Posted: September 05, 2010 at 3:17 PM
any other ideas guys please help!!
Posted By: Velocity Motors
Date Posted: September 05, 2010 at 4:55 PM
I have the same car and when I remote start, the dome light turns on and the car starts and then the dome light turns off afterwards. If you have the system attached to the dome light for door trigger, this will cause the alarm state. You will need to wire in a relay as well as diodes to isolate the dome light trigger from the alarm CPU or grab the door trigger wires independantly and diode isolate them.
Posted By: howie ll
Date Posted: September 05, 2010 at 5:36 PM
Jeff I said that in my first post but I don't think our friend is either listening or understands.
