k20
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=123345
Printed Date: April 03, 2026 at 3:53 PM
Topic: k20
Posted By: gostone
Subject: k20
Date Posted: September 02, 2010 at 9:58 PM
Hello,
I am totally lost on installing the K20 on my Hyundai accent, the documentation is sparse, with references to documents not available.
I am just trying to install 2 actuators (spal) for my 2 door car. Are there any schematics and installation details available?
any help appreciated.....
thanks
shane
Posted By: 91stt
Date Posted: September 03, 2010 at 2:32 PM
So your Spal actuators have 2 wires or 5?
Are you using the actuators only or are you installing the central locking system?
This information is provided only as a reference.
All circuits should be verified with a digital multi-meter prior to making any connections.
Posted By: gostone
Date Posted: September 07, 2010 at 1:25 PM
I am using 2 wire spal actuators, so no central locking. Figured it was easier than going with the 5 wire central locking. The K20 manual seems to mention driving the actuators directly, but all the outputs seem to be relay out.
Any schematics or wiring advice appreciated.
thanks
Shane
Posted By: howie ll
Date Posted: September 07, 2010 at 4:22 PM
Are there six wires on the K20 for locks, if so how are they labelled?
Posted By: 91stt
Date Posted: September 07, 2010 at 8:35 PM
I have never installed a K20 but if this is the manual
K20 Installation Manual
Than you need to wire your system and actuators as follows:
GREEN/ Black: Lock #30 Common Output = Actuator wire that goes +12V during lock
WHITE/ Black: Lock #87A NC = To ground
Violet/Black: Lock #87 NO = +12V
Blue/Black: Unlock #30 Common Output = Actuator wire that goes +12V during lock
Violet: Unlock #87 NO = +12V
BROWN / Black: Unlock #87A NC = To ground
