2001 maxima door locks
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=123388
Printed Date: April 30, 2026 at 9:59 PM
Topic: 2001 maxima door locks
Posted By: TooDark
Subject: 2001 maxima door locks
Date Posted: September 06, 2010 at 10:16 PM
All my wiring diagrams say the door locks are neg. I have 2 different wiring diagrams saying 2 different wire colors. One of the digrams say gray for lock at the SECU, but the wire is sitting at ground and is getting voltage when locked, but they will not lock with 12vots either. I have pulled the door panel also to see if they were negh at the lock module in the door panel. Anyone have done a 2001 Maaxima recently?
Posted By: i am an idiot
Date Posted: September 06, 2010 at 11:30 PM
Audiovox has this information.
WIRE |
COLOR |
POLARITY |
LOCATION |
Power Unlock |
BROWN / YELLOW |
AT MODULE TO RIGHT OF STEERING COLUMN |
PowerLock |
GRAY |
Posted By: TooDark
Date Posted: September 06, 2010 at 11:40 PM
That is what my also has, but the gray is sitting at a ground and is seeing voltage when actuated. But when you give the wire 12volt is sparks. I did not want to fry the module so I quit and trying more research.
Posted By: TooDark
Date Posted: September 07, 2010 at 7:38 PM
I am totly lost with these locks. In hte module there is a gray (pin3) which is the lock, but it activating with 9volts and resting at ground. Now when I put voltage to it they spark like hell.
Posted By: kreg357
Date Posted: September 07, 2010 at 8:12 PM
Bulldog shows this info for your car.
POWER LOCK GRAY (TYPE B) IN PIN 23, @ SECU, See NOTE *2 POWER UNLOCK BROWN / YELLOW (TYPE B) IN PIN 35, @ SECU, See NOTE *2
NOTE *2 THE SECU (Smart Entry Control Unit) IS LOCATED TO THE PASSENGERS SIDE OF THE STEERING COLUMN
It's best ( safest ) to use a Digital Multi Meter to test these wires. You are looking for a (-) pulse. Attach the Red lead to +12v constant source and the Black lead to the suspect wire. The DMM should show +12v pulse with a lock ( or unlock ) pulse. The unit you are installing should be set to output a (-) pulse, basically a ground. ------------- Soldering is fun!
Posted By: Velocity Motors
Date Posted: September 07, 2010 at 8:28 PM
Your not at the right harness at the SECU.
------------- Jeff
Posted By: TooDark
Date Posted: September 07, 2010 at 8:47 PM
I have test all wires in the SECU (all three plugs). The only ones that work are pin 1 GREEN/ YELLOW drivers door only, pin 2 WHITE/ black all doors and pin 3 gray lock. All are sitting at ground normally and are reading max of 9volts on the multimeter when actuated.
Posted By: TooDark
Date Posted: September 07, 2010 at 8:49 PM
I have not connected the unit to the locks. I have tried to test the wires with a wire connected to the lock/unlock and touched it to a fused 12volts.
Posted By: TooDark
Date Posted: September 07, 2010 at 9:07 PM
OK I did it your way with the multimeter. The red connected to 12volts and the black to lock/unlock. The multi shows 12volts when sitting and looses the voltage when actuated.
Posted By: kreg357
Date Posted: September 07, 2010 at 9:35 PM
That would indicate you have the wrong wire. The lock or unlock wire should go to ground when activated thus completing the DMM circuit and showing +12 volts. With Bulldog, Audiovox and info from this site all concurring, Lock is Gray and UnLock is BROWN / Yellow, those are the colors you want to find and test. As a final test, after you have located the correct wires with the DMM, attach a wire to chasis ground and briefly ( ~0.8 sec ) touch the other end to the lock or unlock wire.
Posted By: TooDark
Date Posted: September 07, 2010 at 9:44 PM
Thanks for the help, but I have tested ALL wires in the SECU and the only 3 colors the do anything are the colors stated in one of my earlier in my post.
Posted By: TooDark
Date Posted: September 08, 2010 at 7:05 PM
OK, I found a ORANGE / black and a ORANGE / blue in the door panel that actuates the locks. You had to use the key in the door to test them, using the switch on the door panel did not show a ground throught these wires. Thanks for all the help. These wires are not in the SECU, door panel only.
