compustar/neg when running
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=123390
Printed Date: April 30, 2026 at 6:38 PM
Topic: compustar/neg when running
Posted By: TooDark
Subject: compustar/neg when running
Date Posted: September 06, 2010 at 10:34 PM
What is the pin out for neg when running. I need to connect my bypass to this wire. I am new with compustar starters and they do not list it out on the pin out diagrams
Posted By: i am an idiot
Date Posted: September 06, 2010 at 11:04 PM
Can we get an exact model number of your starter?
Posted By: TooDark
Date Posted: September 06, 2010 at 11:21 PM
6200
Posted By: peppy6669
Date Posted: September 07, 2010 at 12:51 AM
pin#11 black of cn2
Posted By: TooDark
Date Posted: September 07, 2010 at 7:59 AM
Thanks,that is what I figured. Not providing ground when starting. HHHMMMM
Posted By: kreg357
Date Posted: September 07, 2010 at 8:25 AM
Did you change Special Option Group 2 POC #5 programming?  Default is (-) Status Output for CN2 Pin 11, Black wire.
Date Posted: September 07, 2010 at 8:28 AM
That was why I was asking for specifics of his unit.  As kreg stated the wire on your unit is labeled Status Output.  It is what others call Ground While Running.  You should not have to do anything in the programming.  Do you see that wire?
Posted By: TooDark
I have the bypass connected to that wire. I will have to check and see if I did change it.
Posted By: Velocity Motors
Date Posted: September 07, 2010 at 8:49 AM
What bypass are you using ? Compustar systems can use Fortin, iDatalink and bypasskit.com modules via RS232 without the use of GWR wire. If it's something else other an those & the GWR wire is not functioning, you can change any one of the POC's to GWR with the use of a OP500 programmer.
Posted By: TooDark
Date Posted: September 07, 2010 at 10:38 AM
I am using an idata bypass. That is nice to know I could have been using the RS232 connection.
Date Posted: September 07, 2010 at 10:43 AM
You have to program the module to type 2 for RS232 communication and use the 4 pin wire that they gave you in the box.
Posted By: TooDark
Date Posted: September 07, 2010 at 10:59 AM
cool, I will have to give that a try.
Posted By: TooDark
Date Posted: September 07, 2010 at 8:52 PM
Switched to a blade and works great. except for door locks.
