2006 honda crv remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=123422
Printed Date: April 30, 2026 at 12:59 AM
Topic: 2006 honda crv remote start
Posted By: nu1995
Subject: 2006 honda crv remote start
Date Posted: September 08, 2010 at 8:32 PM
I am installing a code alarm ca-545 with a ca-425a. I have it all installed, when i remote start it doesn't start it chugs? programed the tach many times, switched to tachless and still can not get it to fire up?
Posted By: kreg357
Date Posted: September 09, 2010 at 12:34 AM
Please define "Chugs".
Will it start properly with a working key in the ignition cylinder but left at the OFF position?
Any security type lights on the instrument panel?  Perhaps a green key symbol?
What type bypass did you use?  Did it program OK?
Posted By: godd dan it
Date Posted: September 09, 2010 at 2:58 AM
I think he means that it doesnt start at all. Do what kreg said. Put a working key in the cylinder. Try remote starting it. If it starts...its a problem with the bypass. If it doesnt start....then maybe you dont have the correct tach wire hooked up and/or programmed correctly. Dont do tachless...its not reliable.
Posted By: howie ll
Date Posted: September 09, 2010 at 8:44 AM
Either a by-pass or a tach problem.
Posted By: howie ll
Date Posted: September 09, 2010 at 8:45 AM
Sorry, OR incorrect wiring. Try the key in ignition procedure as explained above first to eliminate faulty wiring.
Posted By: nu1995
Date Posted: September 09, 2010 at 9:08 PM
tried that this morning and it work's. So I have a xpresskit xko5 firmware flashed to pkh3 and still not working? if battery is low or will it affect the remote start? I f ing hate bypass modules.
Posted By: kreg357
Date Posted: September 10, 2010 at 5:56 AM
Try a reset on the XK05 ( or re-flash it ) and then re-program it.  If you are running the XK05 W2W, is the Brown GWR wire connected to the remote starts (-) Status Output ( or (-) Third Ignition or (-) GWR ) wire?
Posted By: nu1995
Date Posted: September 10, 2010 at 11:54 PM
it works now all that you said was the problem except I used a t-tap for the power for the bypass and the male side was crooked and not in the center so that was my ultimate problem thanks for your help!!!!!!!
Posted By: howie ll
Date Posted: September 11, 2010 at 1:06 AM
Not having real go but T taps? NEVER EVER, solder and test.
