remote starts but shuts off
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=123495
Printed Date: April 30, 2026 at 9:11 AM
Topic: remote starts but shuts off
Posted By: j98tt
Subject: remote starts but shuts off
Date Posted: September 13, 2010 at 4:52 PM
2003 Chevy express 2500
viper 791xv
works fine with old remote
new remote locks and unlocks but on remote start its starts then shuts off immediately and does this 4 times then alarm beeps and it stops the remote start process
Posted By: t&t tech
Date Posted: September 13, 2010 at 5:14 PM
The new remote is recalling the default settings, you need to program the settings over when using the new remote. You would need to change the tach setting to voltage.
Posted By: howie ll
Date Posted: September 13, 2010 at 5:29 PM
see if it remote starts with the key in the ignition, if so it's a by-pass problem.
Posted By: t&t tech
Date Posted: September 13, 2010 at 5:33 PM
No howard, two clues that says it ain't bypass, it starts and cuts off, and he says the old remote starts up fine,
Posted By: howie ll
Date Posted: September 13, 2010 at 5:37 PM
Your probably right but it used to be 15 secs. when tach wasn't learned, if the poster does what I suggested, if it starts with the key in I'm right, if it doesn't you're right!
Posted By: j98tt
Date Posted: September 13, 2010 at 7:21 PM
it start with the key
but the old remote it does not need the key
Posted By: howie ll
Date Posted: September 14, 2010 at 12:52 AM
You owe me lunch Darren.
Posted By: t&t tech
Date Posted: September 14, 2010 at 5:59 AM
Fine! KFC or subway?
Posted By: howie ll
Date Posted: September 14, 2010 at 6:07 AM
Either but it has to be Kosher, nah who cares. Now I've done the diagnostics you can explain to our poster how to strip his car, find out what make and model by-pass Bet it was a chip on the ignition switch antenna and it has fallen off, then how to get it working.
We are going to get murdered in the Champion's League in Germany tonight.
Posted By: howie ll
Date Posted: September 14, 2010 at 6:10 AM
And I don't think the new remote has been learned properly, didn't our poster say that it STILL starts with the original remote?
Posted By: howie ll
Date Posted: September 14, 2010 at 6:11 AM
Dump both the remotes then relearn them either via the owner's manual or a Bitwriter.
Posted By: t&t tech
Date Posted: September 14, 2010 at 6:17 AM
That's why i was thinkin it couldn't be a bypass problem, but alas i'm a million miles away to verify this.
Posted By: howie ll
Date Posted: September 14, 2010 at 6:22 AM
Well I'm a tad over 3000 so WTH
Posted By: j98tt
Date Posted: September 14, 2010 at 3:30 PM
removed both remotes with channel 12
reprogrammed both remotes still does the same thing
original remote still starts the vehicle
Posted By: t&t tech
Date Posted: September 14, 2010 at 5:35 PM
Howard that isn't a bypass problem.
Posted By: howie ll
Date Posted: September 14, 2010 at 5:50 PM
I think you're right, lunch back with me but I don't have any answers apart from dumping and relearning the remotes.
Posted By: j98tt
Date Posted: September 14, 2010 at 7:53 PM
what is the correct way to dump the remote? going to channel 12 and pressing a button on the remote?
Posted By: howie ll
Date Posted: September 15, 2010 at 12:57 AM
Yes and remember to redo all your remotes.
Posted By: t&t tech
Date Posted: September 15, 2010 at 5:35 AM
I think they used a bitwriter in the original programming, sometiemes it happens to me, where i was using one remote on the system and programmed with the bitwriter and didn't allocate the transmitters to zero, the other remote when used will recall the original settings.
Posted By: howie ll
Date Posted: September 15, 2010 at 12:55 PM
Yes lunch on me Darren, I think you figured it but surely it sends a remote start pulse via * as a default setting.
P.S. Came out of the supermarket just now to find my engine running, must make the * a double pulse....
Posted By: t&t tech
Date Posted: September 15, 2010 at 7:59 PM
Gotta get keypad lock!
