2010 mazda 3 and clifford alarm.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=123515
Printed Date: April 30, 2026 at 11:32 PM
Topic: 2010 mazda 3 and clifford alarm.
Posted By: caryb
Subject: 2010 mazda 3 and clifford alarm.
Date Posted: September 14, 2010 at 8:18 PM
I have a base model 2010 Mazda 3i Sport that I bought a Clifford 330.3x alarm for.
This car has no factory alarm and no factory keyless entry. It does have the immobilzer 'chipped' key (not a smart key or push button start).
No remote start being done.
Do I need any kind of bypass kit for the install? Or can the alarm connect directly to the car?
Posted By: Velocity Motors
Date Posted: September 14, 2010 at 8:34 PM
Directly to the vehicle. No module necessary.
------------- Jeff
Posted By: t&t tech
Date Posted: September 15, 2010 at 5:43 AM
Although the car is perfectly safe as is, only difference the system would make is the keyless entry part of things.
Posted By: ipv_zach
Date Posted: September 15, 2010 at 9:36 PM
yeah no module necessary and the actuators are a little trickey..does it have power locks? because i havent come across any that do without fatory keyless
------------- alarmwizard
Posted By: caryb
Date Posted: September 16, 2010 at 4:58 PM
Thanks Guys! I was pretty sure I don't need any express kit.
No power locks. The only thing that the 3i Sport is missing; but the 2011's will come with them standard.
I had already read that aftermarket actuators don't fit anywhere, so I am only doing the factory actuator and switch to the drivers door.
This is my commuter car, and I won't really need power locks everywhere, but I can add them later on.
Posted By: mdlockard
Date Posted: September 26, 2010 at 1:13 PM
I have a 201 Mazda 3 S with keyless entry. I also have two Mazda non-fob keys with micro chips that work with the car. I'm looking at the Clifford 330.3x and the Viper 5901. I also do not plan to use remote start.
First, will I require a bypass kit if I have the keyless entry?
Second, is there a difference between the Clifford and Viper other than branding and cost?
And caryb, how do you like the 330.3x in your Mazda. Any problems with it? ------------- Matthew Lockard
Date Posted: September 26, 2010 at 1:14 PM
2010 Mazda 3 S six speed manual with no factory alarm (does have factory keyless entry and LoJack installed by dealer).
Posted By: howie ll
Date Posted: September 26, 2010 at 6:06 PM
To the last poster, you only need a by-pass when installing a remote start. No difference the only different (and a better product) Cliffords are G5. To the first poster, you can add door locks, you just need the adaptors for cable locks, tricky but doable, I believe the vehicle is effectively a Ford Fiesta. Ford aftermarket cable lock actuators have been available here since Ford Europe went that way for security reasons in the mid-90s.
Posted By: t&t tech
Date Posted: September 26, 2010 at 7:30 PM
howard have you ever pulled the door skin of an m3?
Posted By: tedmond
Date Posted: September 26, 2010 at 7:43 PM
T&T is stepping into beastly territory haha.
empty your inboxxx too  ------------- Ted
Compustar Expert
Date Posted: September 26, 2010 at 7:47 PM
howieII thank for the quick response. Please let me know how a G5 alarm differs from a Clifford 330.3x or the Viper 5901.
I've been comparing the Clifford IntelliGuard 770, Clifford 330.3x, and the Viper 5901. I do like the IntelliGuard valey/ override switch. What other advantages does it have?
Also, I'd like to have a two way remote since I'm near my car at work and home (but out of site of it). Is the security of a G5 worth giving up the two way remote?
My goal is the most secure set up. I'm not worried about additional features, remote start, etc.
Thanks! Matthew ------------- Matthew Lockard
Posted By: howie ll
Date Posted: September 27, 2010 at 2:29 AM
Less range it's one way only, better build quality and easier programming.
