05 acura tl bypass module
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=123573
Printed Date: May 01, 2026 at 8:30 PM
Topic: 05 acura tl bypass module
Posted By: keung71182
Subject: 05 acura tl bypass module
Date Posted: September 18, 2010 at 6:53 PM
Hey guys,
I am working on a 05 TL. I installed the remote starter without the factory disarm wire attached(didn't want to go through the door). started the car when it was locked, and the alarm went off. So i realize i have to hook that wire up.  I read somewhere that i can install a xk01 module in it. couple questions
1. Will i have to install both the pkh34 bypass module and xk01 at the same time or can i just use xk01?
2. Someone told me that i can do a double pulse on the RCS to disable the factory alarm, is this true?
3. Is there another way to do the factory disarm without going through the drivers door ie; kick panel or something like that?
Thanks for your help
George
Posted By: kreg357
Date Posted: September 19, 2010 at 9:07 PM
1.  The XK01 will not do the Transponder bypass function.  You would need both modules.
2. and 3.  All the info I have indicates that Alarm arm / disarm is done at the Driver Door Module in the door. ( Unless you use a module. )
There are bypass modules that perform both functiuons.  The iDatalink ADS-DLSL-HA and the Fortin EVO-ALL do both.
Posted By: tedmond
Date Posted: September 20, 2010 at 8:50 PM
the evo-all from fortin is a very nice module. it will do everything from door locks, trunk, disarm etc by data and bypass as well.
this is definitly the fastest way to install a unit, but the evo-alldoes come with a high sticker price.
Ted
Compustar Expert
