5901 toggle switch error
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=123583
Printed Date: May 02, 2026 at 5:38 AM
Topic: 5901 toggle switch error
Posted By: android67
Subject: 5901 toggle switch error
Date Posted: September 19, 2010 at 1:08 PM
In Dubai there are no qualified installation shops for DEI products. But some of the guys in these shops have done Viper installs in their home country - Philippines.
So I am working with this guy attempting to install a 5901 alarm/RS.
Using 5901/CANMAX400/XKEYCHGM.
Install so far has the CANMAX400 programmed and with Green.
Factory FOB and Viper Colour remote lock/unlock and activate alarm without issue.
The problem is hitting the "Remote Start" on the Viper remote returns an error - "Toggle Switch Off"
Checking the toggle switch and it is plugged into the 5901 and the switch is set to "ON"
Where should I look to resolve this?
PS I also have a Bitwriter if required to configure ...
Thanks in advance,
Android
Forgot to mention
2009 Jeep Grand Cherokee Limited
Posted By: t&t tech
Date Posted: September 19, 2010 at 3:29 PM
Is your BLACK/ white neutral safety wire seeing ground during remote start?
Date Posted: September 20, 2010 at 9:18 AM
you want the BLACK/ white neutral safety wire to be grounded? during remote start?
I WILL REQUEST THE INSTALLER TO ....
Posted By: Mark Mizenko
Date Posted: September 20, 2010 at 9:25 AM
Yes!
 When the Neutral Safety wire is grounded, the module knows that the vehicle is in park, and allows it to start.
On older vehicles without a built in NSS, you would wire it to the Park/Neutral switch (rarely found these days).
Date Posted: September 20, 2010 at 11:27 PM
I don't import these immigrants to work here, the Arabs do!
It is frustrating enough to accomplish a alarm/RS install in a foreign country without receiving unnecessary comments that have no purpose but sarcasm! Keep your comments T&T they are not required!
Mark Mizenko thanks for you clear and precise response, it will be understood when I pass it on!
