viper 5901 remote start problem on 05 sti
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=123660
Printed Date: April 18, 2026 at 7:18 PM
Topic: viper 5901 remote start problem on 05 sti
Posted By: axd114
Subject: viper 5901 remote start problem on 05 sti
Date Posted: September 24, 2010 at 8:34 PM
I have a 2005 subaru wrx sti. Alarm model is viper 5901 and the bypass module they used i believe is a 556u. I just recently got remote start and have been having this problem. When the engine is cold remote start will start the car and within a second the engine shuts off just like when trying to start the car without a transponder key but when i go in the car and start the car with a key it starts just fine. Once the engine warms up remote start works like a charm. I am just wondering what could be causing this?
Posted By: godd dan it
Date Posted: September 24, 2010 at 10:39 PM
Was the system programmed for voltage or tach? It sounds like thats the problem. I try to use the tach wire for remote starters....its more reliable.
Posted By: axd114
Date Posted: September 24, 2010 at 11:15 PM
I'll call the shop tomorrow and see which one. Thanks.
Posted By: t&t tech
Date Posted: September 25, 2010 at 6:17 AM
definitely tach issue!
