’02 deville service light comes on
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=123726
Printed Date: May 01, 2026 at 1:50 PM
Topic: ’02 deville service light comes on
Posted By: godd dan it
Subject: ’02 deville service light comes on
Date Posted: September 30, 2010 at 3:59 PM
Ok I installed an alarm/remote starter on a '02 Cadillac Deville. I used the XK09 Xpresskit (W2W). Everything worked fine when I gave the customer his car. Now whenever he remote starts the car, the service stability system comes on. This only happens when its remote started. I was thinking maybe its the parking lights. I know on the Monte Carlo I worked on not too long ago said to wire in a diode for the parking lights or the check engine light will turn on. Do you think this is the same problem? I wont be seeing the car in a few days....I figured I would ask ahead of time.
Thanks.
Posted By: howie ll
Date Posted: September 30, 2010 at 5:55 PM
Is there an extra ignition wire that needs to be wired up? As I said before, never see them here, we've got Jag,BMW Benz Audi and Lexus so they're as rare as rocking Horse s**t having said that use the search box at the bottom of the page, I'm sure this has come up before.
Posted By: howie ll
Date Posted: September 30, 2010 at 5:59 PM
I just did what I told you to do, you must power the second ignition wire.
Date Posted: September 30, 2010 at 7:53 PM
I did do that. I actually connected the 2nd ignition to the 2nd ignition on the remote starter. Connected accessory 1 wire. I was left with accessory 2 without a connection. But I used a relay to power that. Im really thinking that its the parking lights, but I could be wrong. I will see when I get to look at the car again.
