07 toyota camry
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=123772
Printed Date: May 01, 2026 at 7:30 AM
Topic: 07 toyota camry
Posted By: pitoaudiovisual
Subject: 07 toyota camry
Date Posted: October 04, 2010 at 10:09 AM
I did an install for an 07 Toyota Camry with a crimestopper 500 and the car remote starts for a few then turns off. Its not a bypass issue the bypass is working fine but also on the dash there is a VSA and ABS light on. Also when the alarm arms and disarms no flashing lights but when the car remote starts the lights turn on.
Confidence is the key to any project!!
Posted By: icearrow6
Date Posted: October 04, 2010 at 12:17 PM
When the vehicle stops after you remote start. Does it try to restart again?
If if does then I would check the TACH wire to make sure is secure and a DMM to verify that you are getting a reading.
Date Posted: October 04, 2010 at 1:28 PM
yes it does i thought i programmed the car to work off of voltage but i will try to connect the Tach and see what happens. Do u have any idea why the VSA and ABS light would go on as its remote starting tho.
Posted By: kreg357
Date Posted: October 04, 2010 at 5:50 PM
Did you connect the remote starters' outputs to both Starter wires and both Ignition wires at the ignition switch harness?
Posted By: Mike M2
Did you connect both ignition wires?
Tach is an easy connection, black right at the OBD connector...
Mike M2
Tech Manager
CS Dealer Services
Posted By: kgerry
Date Posted: October 04, 2010 at 5:53 PM
that usually indicated a required IGN or ACC is not being powered up.....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Date Posted: October 04, 2010 at 8:43 PM
ok i connected both ignitions and starters but now what happens is the car starts fine some times but then other times the car wants to start and the LCD remote says the car is on and the lights inside the car are on as well as the parking lights but the vehicle is not on. I put the remote starter to work by voltage not by tach could that be the reason but y sometimes yes and sometimes no.
Posted By: Mike M2
Date Posted: October 04, 2010 at 8:58 PM
Try it and find out. Again, a very easy connection...
Mike M2
Tech Manager
CS Dealer Services
Posted By: kreg357
Date Posted: October 04, 2010 at 8:59 PM
Switch to Tach mode and use the Tach signal, Black wire at Pin 9 of the OBD 2 connector, as Mike suggested.
Posted By: sotujr
Date Posted: October 04, 2010 at 11:59 PM
As for the parking lights not flashing during lock/unlock....make sure the light switch is turned off and not on "auto".
Posted By: howie ll
Date Posted: October 05, 2010 at 9:53 AM
Actually Mike it's black with silver dots, pin 9 just to be anal.
Date Posted: October 05, 2010 at 1:57 PM
ok i got the lights to . It was programmed to not flash when armed and disarmed and i will try the tach when i get a chance its a customers car so im waiting to see if they are still having a problem and come back. Thank you guys so much again.
