name this part: flexible conduit to door
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=123877
Printed Date: April 30, 2026 at 2:29 AM
Topic: name this part: flexible conduit to door
Posted By: nitroxdm
Subject: name this part: flexible conduit to door
Date Posted: October 11, 2010 at 1:40 PM
I'm putting power locks in a base model car. There isn't a flexible conduit from the frame to the door to run wires through. I would like to pick up the stock ones that came with this model car. But I have no idea what to call these things. It's hard to find a part you can't reference.
Any suggestions where to buy?
The car: 2002 Chevy Cavalier
Posted By: howie ll
Date Posted: October 11, 2010 at 1:50 PM
Door tubes, go to a wreckers yard.
Posted By: nitroxdm
Date Posted: October 11, 2010 at 1:59 PM
Door tubes. Hmmm... sounds plausible.
Google shows up stuff like this Door Tubes
I will have to check out the junk yards.
Posted By: Mike M2
Date Posted: October 11, 2010 at 3:42 PM
The proper name here is a door jamb boot...
------------- Mike M2
Tech Manager
CS Dealer Services
Posted By: howie ll
Date Posted: October 11, 2010 at 4:09 PM
Sounds like a line from "Come Together" by the Fab Four.
Posted By: KarTuneMan
Date Posted: October 13, 2010 at 12:03 AM
And the winner is......... Mike M2 -------------
Posted By: howie ll
Date Posted: October 13, 2010 at 1:36 AM
Hello Gary.
A rose by any other name etc. We're back to boots and trunks earths and grounds here.
Posted By: Mike M2
Date Posted: October 13, 2010 at 6:55 AM
Simply a matter of different terms from different countries. I would never call a cigarette a fag....  ------------- Mike M2
Tech Manager
CS Dealer Services
Posted By: howie ll
Date Posted: October 13, 2010 at 6:59 AM
Very funny, thus I concede. (Yes I'm aware of the yiddish for fairy).
Posted By: tedmond
Date Posted: October 13, 2010 at 5:39 PM
ahah i was about to suggest door wiring boot.
looks like Mike M2 nailed this one on the head. ------------- Ted
Compustar Expert
Posted By: howie ll
Date Posted: October 14, 2010 at 1:03 AM
Other names:-
Germany (literal translation) tubes as means of passing cables from car to door with sealing grommets either end.
Italy, don't bother everything will be rotten and corroded in 2 years.
France, don't bother all the electrics will fail, Peugeot alternative, let's design it so it cuts the cables after a couple of years.*
UK (Rover/BL dog days, early 70s) We can't afford it.
*Honestly true.
