altima 2002
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=123884
Printed Date: April 30, 2026 at 12:58 AM
Topic: altima 2002
Posted By: muaiad97
Subject: altima 2002
Date Posted: October 11, 2010 at 8:02 PM
hi all
i installed  remote starter in this kind of the car too many  but today i got problem with this  car the problem is  the car stars remotely but after 2 min shuts off and start again for 1 min and shuts off  and stars again for 1 min and stops . the remot starter is autostart  two way . i installed to many like this starter in all kind of the car i never had problem  without even conecting the tech wire i use techless program .its not tech issue  because if it was tech issue the car will not even start it give 5 flash . any help pleass. the car is neissan altima 2002 and the starter is autostart two way FM.
Posted By: Mark Mizenko
Date Posted: October 11, 2010 at 9:31 PM
Why not do a tach connection?  It's the most reliable,  and will probably solve your problem.
