how do i program 2001 toyota previa?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=123891
Printed Date: April 29, 2026 at 5:18 PM
Topic: how do i program 2001 toyota previa?
Posted By: radzy
Subject: how do i program 2001 toyota previa?
Date Posted: October 12, 2010 at 4:34 AM
i'm having problems programming a toyota previa 2001 model second key . i have a master key with "unlock" & "lock" central locking on it .
i am following this tutorial :
https://www.etimago.com/yaris/TSB/TS-EL009-07%28Programming%20OEM%20Wireless%20Door%20Lock%20Remote%20Transmitters%20%29.pdf
i get the confirmation of 1 cycle lock and unlock but when i start the car , still not working .
which key do you use for this tutorial ? and do you swap keys at a certain step?
do i use the master key or the second key ?
i need a bit of help . posted_image i'm going bonkers !!!
Posted By: radzy
Date Posted: October 12, 2010 at 4:36 AM
also do i "add" , or "rewrite" mode if i am just programming a blank ??
whats the difference ?
