2010 tacoma ecm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=124297
Printed Date: April 28, 2026 at 1:29 PM
Topic: 2010 tacoma ecm
Posted By: maxcat
Subject: 2010 tacoma ecm
Date Posted: November 05, 2010 at 6:47 PM
hey all, I have a 2010 toyoto tacoma to do next and it looks like I need to get to the ecm behind the glove box for a couple connections for the fortin bypass module. Just wondering if anyone has had to get to the ecm, and how hard it was to get to it. Is it easiest to remove the glove box or can you get to it from underneath. Any tips or insight would be appreciated.
  Thanks in advance
Posted By: Mike M2
Date Posted: November 06, 2010 at 7:06 AM
Just pop the box down and remove the shock rod on the right side, the box will pull off. The ECM is all the way to the right, very easy to get to. You should need the 2nd plug from the bottom...
Mike M2
Tech Manager
CS Dealer Services
Posted By: maxcat
Date Posted: November 06, 2010 at 12:08 PM
Thanks Mike, I appreciate the help
