Saturn SL2 Wiring Help
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=12431
Printed Date: April 25, 2026 at 3:07 AM
Topic: Saturn SL2 Wiring Help
Posted By: matto2002
Subject: Saturn SL2 Wiring Help
Date Posted: April 19, 2003 at 3:56 PM
I'm trying to install a Crimestopper DC2003II on my SL2. I'm having problems finding the wires in the console for the door triggers and such. Can anybody help?
------------- Matt
Posted By: odie34567
Date Posted: April 19, 2003 at 6:00 PM
i'm trying to do the same thing i have a 95 Saturn SL2 i went to https://www.bulldogsecurity.com/wires2/pr_showmodels.asp?modelid=15229 it has somewhat of a wireing diagram and tells you to look for the wires to unlock it is a light blue in the center console behind fuse box, and the unlock is in the drivers kick panel it is white and both are +(pos.) ------------- Odie
Date Posted: April 19, 2003 at 6:10 PM
I have that same diagram for the 96, but I'm kinda confused, because I'm seeing several light blue and several white wires in there. Also do you by chance know anything about the door triggers? I can't figure out where that wire is for anything. All i can find are two groups of wires below the cig. lighter.
------------- Matt
Date Posted: April 19, 2003 at 6:11 PM
also, i don't want to sound stupid or anything, but the drivers kick pannel, is it the console that gives you access to the back of the fusebox, or is it the plastic trim on the drivers door side?
------------- Matt
Date Posted: April 19, 2003 at 6:17 PM
i think by the dr. side kick panel they mean where your left foot would be when your siting in the drivers seat what i'm going to do when i get home is where the relays for the locks are you can pull thet off when you move that metal bar out of the way and find the wires that go to those relays and test them with a probe. ------------- Odie
Date Posted: April 19, 2003 at 6:57 PM
That dosen't sound like a bad idea. Thanks for the help. Maybe I can finally get this thing figured out. Matt ------------- Matt
Date Posted: April 19, 2003 at 7:01 PM
Do you happen to know anything about the door trigger wire that is supposivly under the ashtray? (White -)
------------- Matt
Posted By: draasch
Date Posted: April 19, 2003 at 7:24 PM
hey guys this info is for the 96. see if it will help...
Constant 12 volts RED & RED IGNITION SWITCH HARNESS
Ignition 12 volts PINK IGNITION SWITCH HARNESS
Starter YELLOW IGNITION SWITCH HARNESS
Dome Light WHITE (-) AT FUSE BLOCK IN DRIVER KICK PANEL *
Trunk Pin Switch RED / BLACK (-) AT LIGHT IN TRUNK
Parking Lamp BROWN (+) AT HEADLIGHT SWITCH OR FUSE BLOCK
Power Lock L BLUE DRIVER KICK #202
Power Unlock WHITE PANEL
#202- See Positive Pulse Door Lock Diagram. * WHITE Wire Can Also Be Found In Passenger Side Rear Body Harness Wrapped With Green Tape ------------- Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Posted By: draasch
Date Posted: April 19, 2003 at 7:26 PM
by the way make sure check all wires with a volt meter.
NOT A TEST LIGHT!
good luck. ------------- Good Luck
David
Ace Security
813-376-9778
Tampa
Date Posted: April 19, 2003 at 8:12 PM
Thanks for the info Dave. I have another question for you though. It only has one wire listed for the door trigger, but my alarm has 2 wires for the for the door pin hook up. I don't have my instruction manual to tell you exactly what they do. Any suggestions for this?
------------- Matt
Posted By: CCRoadshop
Date Posted: April 19, 2003 at 8:23 PM
Well guys...the answer to your problems should be this..... on the passenger rear side take off the part of the rear seat that sits right next to the actual seat...might sound confusing...but its long and vertical and looks like its apart fo the seat but isnt.... There should be a keyless entry box right there(black box) should be able to find the wires there.....please use meter.......that should work....def use a meter tho as air bag wires might be found in the black box.... ------------- Installer - Circuit City Roadshop(2 1/2 years n counting)
Alpine CDA7894(soon to be the cda9815)
Pioneer XM unit(soon to be direct link alpine)
Audiovox 995C alarm/remote start
Date Posted: April 19, 2003 at 8:30 PM
my alarm has a pos+ trigger and a neg- trigger do i have to hook bot up or just one?
------------- Odie
Date Posted: April 19, 2003 at 8:33 PM
for doors??????? should just be one ------------- Installer - Circuit City Roadshop(2 1/2 years n counting)
Date Posted: April 19, 2003 at 8:36 PM
can you be more specific about this black box like exactly wher it is located like between therear pass. door and the seat? is it on the seat or side wall?will it be the color of the seat or interior? ------------- Odie
Date Posted: April 19, 2003 at 9:04 PM
Here is my problem: I don't know what to hook up, do I have to use them both or what? These were took directly from the instruction manual PIN 7: VIOLET WIRE: (+) DOOR TRIGGER INPUT Connect to Positive type door switches that show +12 Volts when the door is open and Ground when the doors are closed. Positive type door switches are found on many Ford, Lincoln and Mercury vehicles. PIN 10: GREEN WIRE: (-) DOOR TRIGGER INPUT Connect to Negative type door switches that read ground when a door is opened and 12 volts when all doors are closed or connect to the circuit that triggers the vehicle’s dome
------------- Matt
