compustar automatically locks the doors
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=124342
Printed Date: April 28, 2026 at 4:45 PM
Topic: compustar automatically locks the doors
Posted By: dieselboy_01
Subject: compustar automatically locks the doors
Date Posted: November 08, 2010 at 9:30 PM
I have a compustar remote start in a 2008 ram 2500 diesel manual transmission. The starter has a bypass module and a pats key transponder. About a week ago the truck started automatically locking the doors. It does not matter which way I unlock the truck with the remote start or the OEM fob. It takeas approx 45 secs and the lights flash then another 15 seconds and then it locks. Not sure what has happened, can it be in a different program or is the starter buggered up?
Posted By: 91stt
Date Posted: November 08, 2010 at 10:35 PM
which compustar brain do you have?
------------- This information is provided only as a reference.
All circuits should be verified with a digital multi-meter prior to making any connections.
Posted By: howie ll
Date Posted: November 09, 2010 at 2:54 AM
You "appear" to have programmed it for passive arm and lock, go into the programming and turn it off!
Date Posted: November 09, 2010 at 9:48 PM
That is what I was thinking. The remote is a RF-1WG2-AM. How do I turn it off?
Date Posted: November 13, 2010 at 10:09 AM
Nobody can tell me how to turn it off?
Posted By: Velocity Motors
Date Posted: November 13, 2010 at 10:20 AM
Press unlock and trunk release at the same time for 1/2 second. Parking lights will flash 2 times to let you know it's out of passive mode.
BTW: It's on the back of the remote control
------------- Jeff
Posted By: 91stt
Date Posted: November 13, 2010 at 11:02 AM
To program the various options I need to know which brain you have. Each program position is different depending on brain used. It does not matter which transmitter you have.
Date Posted: November 13, 2010 at 5:26 PM
Thanks,
I will try the tunk and inlock button. If that does not work I will look at the brain and get a number off it.
Date Posted: November 15, 2010 at 7:38 PM
Thanks that fixed it.
