05 hyundai elantra viper 5101?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=124387
Printed Date: March 18, 2026 at 12:38 PM
Topic: 05 hyundai elantra viper 5101?
Posted By: evorider
Subject: 05 hyundai elantra viper 5101?
Date Posted: November 10, 2010 at 9:08 PM
ok i have done a good deal of reading on my car and am just curious if i am planning to hook everything up right and have a few questions. here is what i am planning to connect the viper harnes(left) to wires in my car(info from 12volt car diagrams on right). i have tested the wires and all seem to be correct to diagram.
RS system is the viper 5101 or the python 1401
H1/2-- red--- (+) 12v constant input----------to---- red and pink 12v wire in ignition harness
h1/3--brown-- (-)20ma horn output------to (-) horn trigger red wire (i dont need a relay right?)
 h1/5--black-- (-) gound----- easy
h1/8--green-- (-) door trigger input---- to yellow (-) wire near ETACM
h1/10--WHITE/ blue-- (-) remote start/ turbo timer activation input------ (not sure if i need this one or where it would even go)
h1/11-- white-- parking light output----- to blue (-) wire near ETACM
h1/12--orange-- (-) 500ma ground when armed--- goround
h2//9--wiolet/white-- tachometer input--- to tach wire in gage cluster
h2/10--dark blue-- (-)200ma status output----(i think i would have to somehow set this up with the keysense wire but i am not sure)
h2/11--pink/white-- (-)200 ma flex relay control output---(not sure what to do with it)
h2/15--grey-- hood pin input--- easy eonugh
h2/17--brown-- (+) brake shut down--- to white (+) brake wire behind brake pedal
h2/18--BLACK/ white-- (-)neutral safety input--- to e brake wire in center councel
h3/1--pink-- ignition 1 input/output---to orange ignition wire
h3/2--RED / white--fused ignition 2/flex relay-- to red and pink 12v constant
h3/3--orange-- accessory output--to green accessory whire
h3/4--violet-- starter output-- to white starter wire
h3/5--red-- ignition 1 input-- to orange ignition wire
h3/6--pink/white--ignition2/flex relay output-- to yellow second accessory wire
h3/7--pink/black--(+)flex relay input 87a keyside --- to (not quite sure but i think this is part of the key sense relay setup ?)
h3/8--RED / black--accessory/starter input--to (this can go to either accessory or starter wire right?)
please tell me if im wrong or am missing something
i am trying to setup horn honk, light flash, keyless entry, remote start and i will eventually wire in a trunk release relay and solenoid... i much appreciate the help in advance if anyone is willing to take the time to look this over for me and make any corrections or give me any advice! i love this site and wish i would have found it sooner!!
Posted By: evorider
Date Posted: November 10, 2010 at 9:10 PM
oh sorry heres the link to car info     https://www.the12volt.com/installbay/forum_posts.asp~TID~87107
Posted By: another-kelly
Date Posted: November 10, 2010 at 11:14 PM
i edited your post/quote below to reflect the changes for you to make. also, don't forget to plug in the 2 pin metal switch or your remote start won't work
H1/2-- red--- (+) 12v constant input----------to red or pink 12v wire in ignition harness
h1/3--brown-- (-)20ma horn output------to (-) horn trigger red wire (no relay needed)
h1/8--green-- (-) door trigger input---- to yellow (-) wire near ETACM (only if it's a manual transmission, otherwise do not connect)
h1/10--WHITE/ blue-- (-) remote start/ turbo timer activation input------ do not connect
h1/12--orange-- (-) 500ma ground when armed--- do not connect
h2/10--dark blue-- (-)200ma status output---- do not connect
h2/11--pink/white-- (-)200 ma flex relay control output---do not connect
h2/18--BLACK/ white-- (-)neutral safety input--- to e brake wire in center console (only if it's a manual transmission, if you have an automatic trans just ground this wire)
h3/2--RED / white--fused ignition 2/flex relay-- to red or pink 12v constant
h3/5--red-- +12V input-- to red or pink 12v constant
h3/7--pink/black--(+)flex relay input 87a keyside --- do not connect
h3/8--RED / black--accessory/starter input--to red or pink 12v constant
Posted By: evorider
Date Posted: November 11, 2010 at 2:47 PM
it is manual trans...
y dont i need the (orange goround when armed) wire?
or the h3/7--pink/black--(+)flex relay input 87a keyside ?
if the car has a key sense wire.. wont it need a + pulse to make it think the key is there so it will start properly??
and thanks alot for the help it is much needed and appreciated.... seeing as i dont wanna eff up my car!!
Date Posted: November 11, 2010 at 4:42 PM
or the h3/7--pink/black--(+)flex <A style="COLOR: #000000" class=orglb title=relays href="https://www.the12volt.com/relays/relays.asp">relay</A> input 87a keyside ?
the orange ground when armed wire is an output from the viper unit, not an input. when you lock the vehicle with the remote, that orange wire will output ground so that you may connect other devices to it and they can be active when the viper is locked/armed (though your unit doesn't have an alarm, same concept/terminology) it would be used for something like say a starter kill or the old scanning blue led lights people liked a decade ago. unless you're adding something of that sort, then you don't need to connect that orange wire to anything.
the pink/black wire is pin 87a of an internal relay on the viper unit. it's main use is for isolating ignition switches from the rest of the vehicle (on that one circuit of course). mostly just used for some late model toyotas or nissans, exact models escape me at the moment. but if you were to look at a standard bosch relay, the RED / black is pin 87, pink/black is pin 87a and pink/white is pin 30 (pins 85 and 86 are internal, kinda)
very few vehicles need to actually see the keysense wire powered up in order to remote start without any issues, your elantra is one that does not require the keysense to be powered
Date Posted: November 11, 2010 at 4:44 PM
oh and for future reference, most vehicles have a negative keysense and not a positive keysense wire.
Posted By: evorider
Date Posted: November 11, 2010 at 8:30 PM
i did see somewhere that most key senses wires ar -  but my spec sheet said +... i had not tested that yet so i was not sure.
thanks alot for the help....i love learnin stuff like this it can come in usefull for so much stuff.  theres nothing sticking out that im looking over that you can see is there?
Date Posted: November 12, 2010 at 4:11 PM
nothing that i see in particular. just make sure that the door trigger wire you connect to the car is a true door trigger and not a dome light wire that fades on/off or has a delay before turning off after shutting all doors.
also, make sure to read and get a good comprehension in the manual about how to properly set up and enter the "ready mode" for manual transmissions
Posted By: evorider
Date Posted: November 12, 2010 at 7:48 PM
Ok... i got tthe majority of everythin in... except hood pin ...tach and brake switch..... i am just ttying to get my locks to work... but they wont latch or anything with the remote... and everything seems drained of power when trying to lock manually.... any ideas?
